scale along z axis ignore normal constraint via python
Window 10 x64, Nvidia GTX970
Broken: 2.76 3555ef1
Worked: 2.76b f337fea
using "bpy.ops.transform.resize(value=(1, 1, 0), constraint_axis=(False, False, True), constraint_orientation='NORMAL')" on selected faces gives unexpected result
after selecting all faces of the mesh "1", using "bpy.ops.transform.resize(value=(1, 1, 0), constraint_axis=(False, False, True), constraint_orientation='NORMAL')" via console gives different result unlike doing it by hand.
Nicola (n1k0l4) added a project: BF Blender.
Nicola (n1k0l4) set Type to Bug.
Nicola (n1k0l4) added a subscriber: Nicola (n1k0l4).
Nicola (n1k0l4) created this task.
Nicola (n1k0l4) raised the priority of this task from to Needs Triage by Developer.
Sergey Sharybin (sergey) triaged this task as Normal priority.
@Campbell Barton (campbellbarton), is it because of viewport requirement for the operator to run or so?
