bpy.ops.wm.append / link is broken
Closed, InvalidPublic
Win7 64bits / 760 GTX
Broken: 2.76 to 2.76b
Worked: 2.75 and before
The bpy.ops.wm.append and bpy.ops.wm.link command doesn't seem to import items correctly.
This code is running well on the 2.75, but doesn't do anything on the 2.76 release. There are no error message in the console but nothing object are imported.
folderpath = "C://ProjectsBlender"
filename = "my_file.blend"
datablock = "Object"
object_selected = "my_object"
bpy.ops.wm.append(directory=folderpath+filename+"/"+datablock+"/", filepath=filename, filename=object_selected)
Vincent Girès (VincentG) set Type to Bug.
Vincent Girès (VincentG) created this task.
Vincent Girès (VincentG) raised the priority of this task from to Needs Triage by Developer.
Bastien Montagne (mont29) closed this task as Invalid.
I don’t know if that code worked in previous version of Blender, but if it did it was by mere accident. Here is correct code, which is working here (once adapted to linux paths):
import os
object = "my_object"
bpy.ops.wm.append(directory=os.path.join(folderpath, filename, datablock), filename=object)
Thank you!
Sorry to have considered this as a bug.
