Daily build glossy material crashes blender directly.
Windows 10, actualy i got 2 graphic cards but the nivdea gforce630M is used, but happen to when on CPU render
Broken: (example: 2.76 8dea065
Worked: (optional) (the release version of 2.76 works)
Not sure if it is ok to report bugs for daily builds, but as soon as i want to make glossy material Blender crashes
I got only the startup cube, select cylces renderer, and want to assign it a glossy material, and then it crashes.
It doesnt matter if i disable Cuda, and use CPU instead.
Peter Boos (PGTART) set Type to Bug.
Peter Boos (PGTART) created this task.
Peter Boos (PGTART) raised the priority of this task from to Needs Triage by Developer.
Bastien Montagne (mont29) triaged this task as Needs Information from User priority.
Did you try with latest build? the one you link to is 2-3 days old already, iirc issues there were fixed, and I get no crash here with current master…
Aaron Carlisle (Blendify) closed this task as Resolved.
Aaron Carlisle (Blendify) claimed this task.
I had the same build and it crashed for me however after updating to 48f298f this works fine. Closing but please make sure to grab a new build.
