Crash when UV unwrapping non-manifold object
Windows 10 64 bit, 980ti
Broken: Recent master (d28431a)
When unwrapping a non-manifold object (e.g. plane), Blender crashes with an EXCEPTION_ACCESS_VIOLATION error.
  • Add a plane
  • Enter edit mode, select everything
  • Press U>1 to unwrap.
Greg Zaal (gregzaal) raised the priority of this task from to Needs Triage by Developer.
Greg Zaal (gregzaal) updated the task description. (Show Details)
Greg Zaal (gregzaal) set Type to Bug.
win7 x64, gtx 580
Same here. For me crashes only if UV/Image Editor is open.
Sergey Sharybin (sergey) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.Nov 23 2015, 2:17 PM
Confirmed by Joshua in IRC.
@Brecht Van Lommel (brecht), mind having a look?
This is Windows only I guess, does anyone have a backtrace?
still somthing strange is going on. look at this file
unwraping objects here with latest build (winx64 c3e7dfa) crashes blender, or distorts uvs. 2,76b unwraps this objects fine. latest working build for me d96ffde
Hi, I got something similar, although it doesn't make Blender crash every time, seems quite random, but related.
Some times I get a different "glitchy" unwrap result and 1 in 5 times Blender crashes. Sometimes Non-manifold meshes make blender crash right away, other times they don't (same geometry/file). Some times I get different Unwrap result every time I execute it, other times I only get a different result if I exit edit mode and enter again.
Sys info: W10 64, GF630, Blender 2.76.2 (22ec7b1)
It should really be fixed now, actually built and tested on Windows instead of guessing what the issue was.
