Missing Render Border Menu items
Broken: (example: 2.69.7 4b206af, see splash screen)
Clear Render Border has no menu item in 3D View
Render Border has no menu item in 2D View
Clear Render Border has no menu item in 2D View
Render border doesn't draw a red rectangle in 2D View. Not sure about this issue though. The red border could indeed disturb. And in 3D view it has the red rectangle.
No Blend file necessary. Open Blender. Switch to camera view. In 3D View click at menu item Render Border in the View menu. Define a rectangle to render. Press F12. Now try to clear the render border by menu. Mission impossible. Menu item not existent. In 2D View both menu items are missing. But hotkey functionality is there.
Attached image explains the issue even better.
{F261717}
Reiner Prokein (tiles) updated the task description. (Show Details)
Reiner Prokein (tiles) raised the priority of this task from to Needs Triage by Developer.
Reiner Prokein (tiles) set Type to Bug.
Argh, i wish i could edit images. The other half of the image was not meant to be publically shown :/
@Reiner Prokein (tiles), you should be able to re-upload the image by going to the corresponding file page: https://developer.blender.org/F261717
Thanks Sergey :)
I was not able to edit it, but i was able to remove the wrong image. This image here was meant to be uploaded:
Now, as for UI and usability..
Think i'll agree clearing render border bakes sense to be added to the viewport menu.
Displaying red border in the image editor is a bit of an overkill. You kind of aware of this anyway. What i'm not sure about here is whether we should really have it a code feature to define a render border from the image editor. It was a nice experiment, but seems so far only used during development? In this case we can re-implement as an addon enabled by developers.
If we'll keep such feature, it makes sense to add it to the menu perhaps.
@Julian Eisel (Severin), mind having a look here?
Sergey Sharybin (sergey) triaged this task as Normal priority.Dec 1 2015, 1:02 PM
Well, most users will most probably not even know this feature exists in UV Editor. It has no menu entry ^^
I find it nice to have :)
Since render border set, clear menu items are next to clipping border...
Noticed behavior of Clipping border is a toggle.
We could expose render border as toggle too, if border's visible, clear, else set.
Menu item would need to check R_BORDER or V3D_RENDER_BORDER.
