Empty Rigging Docs
There are a couple of blank rigging pages however advice is needed on what needs to go in them or to delete them
http://blender.org/manual/rigging/skinning/retargeting.html
http://blender.org/manual/rigging/skinning/objects.html
For the objects page I found that this page links to it:
http://blender.org/manual/rigging/skinning.html
In Blender, you have two main skinning types:
  • You can :doc:Parent/Constrain Objects to Bones </rigging/skinning/objects> - then, when you transform the bones in *Pose* mode, their "children" objects are also transformed, exactly as with a standard parent/children relationship... *The "children" are* never *deformed when using this method*.
  • You can :doc:Using the Armature modifier on entire Mesh </rigging/skinning/obdata>, and then, some parts of this object to some bones inside this armature. This is the more complex and powerful method, and *the only way to really deform the geometry of the object*, i.e. to modify its vertices/control points relative positions.
Aaron Carlisle (Blendify) set Type to Bug.
Aaron Carlisle (Blendify) created this task.
Aaron Carlisle (Blendify) raised the priority of this task from to Needs Triage by Developer.
Sergey Sharybin (sergey) triaged this task as Normal priority.
@Campbell Barton (campbellbarton), think we really need to have some procedure to deal with the documentation bugs. Currently i don't know who handles those, and seems nobody even triages them which is rather annoying.
I did a quick review of the rigging category.
For the rigging chapter:
Intro gives the user a breif description of rigging.
Constraints is a reference manual for Constraints.
Armatures is a reference manual for Armatures, tools, panels, properties.
Posing seems to have good topics (most seem to be animation topics).
Skinning is ok, but seems like it could be improved/updated.
The Skinning -> Retargeting page is blank.. Retargeting is applying a premade Animation to a Rig (may also be a motion capture topic).
This seems to be an intro page for 'Skinning'.
https://www.blender.org/manual/rigging/skinning/introduction.html
This seems to be the main page or 'Skinning'.
https://www.blender.org/manual/rigging/skinning/obdata.html
I think Object rigging should have its own page, for basic rigging.
I think Retargeting should have its own page if kept, listing some common methods used in blender.
I dont know much about retargeting, as a subject.
Hi Koil,
I'm working my way through editing the Rigging chapter.
I've just finished a first edit on the first half of the Constraints section.
I'll keep moving forward from here and will look at the blank pages as I get up to those sections.
Daniel
Aaron Carlisle (Blendify) closed this task as Resolved.Sep 22 2018, 9:53 PM
