Kernel security check failure #47075
13 Participants
Reference: blender/blender#47075
Windows 10/NVIDIA Geforce 920M
2.76b
When i use blender cycles i get an kernel security check failure error and my pc restart.
Added subscriber: @Ridiaan
We need more information...
What kind of scene do you render? Does it happen with the default Cube too?
Computer restarts are usually a driver error, make sure you use latest nvidia drivers. Also note that the 920M is pretty low-end, and not really suited for GPU rendering.
I do have the last version of my driver. I usually do simple things. It happens when I close the program, but not during a render.
Added subscriber: @naitsok
Hello,
I also have the same problem. Just installed fresh Windows 10 and Blender 2.76b. Card Geforce GTX 860M. When Blender starts it uses Blender render by default. If I try to switch to Cycles render I get KERNEL_SECURITY_CHECK_FAILURE error, blue screen and my computer restarts.
I solved my problem by right clikcing on the blender.exe and run it whit a powerful graphic procesor. (Do not whit the integrated graphics.)
Thanks, Eduard! It works. I already tried to change to Nvidia in user preferences but it did not help much.
I am glad to help you.
Added subscriber: @Tetardd
I have Windows 10, NVidia 840m and Blender 2.76b and found a same error + blue screen + restart when trying to change the colour of the background in the World object.
Added subscriber: @YanivGershoni
I have the same problem, tried to run with the internal card and with Nvidia, sometimes I have crash and sometimes not. also the build bot version cause this BSOD.
I ask Microsoft about that and have a lot of DMP files from the BSOD here:
http:*answers.microsoft.com/en-us/windows/forum/windows_10-performance/windows10-bsod-kernel-security-check-failure
it's start after the new update (new Win10 build), it's not occur on the old Win10 build that I have after upgrading from Win7.
Added subscriber: @Blendify
Seems like a common issue but I don't think it is something that can be solved from Blender's side.
Added subscriber: @LukasStockner
BSODs and simular stuff (e.g. kernel panic on Linux) can only be caused by code running with kernel privileges, which is only the case for the OS and drivers, not for Blender (note that "kernel" refers to the OS component here, not the Cycles compute kernels).
Therefore, this has to be caused by a bug inside of the graphics driver. Maybe triggering the bug could be avoided from the Blender side, but I still wouldn't really consider this a Blender bug.
Added subscriber: @Strad
Geforce 880m card, Win 8.1, same error if I don't ensure that blender runs with the high performance card rather than the low performance one. Only started getting this BSOD since the upgrade to Blender 2.76b so I'm inclined to think this is a Blender issue with the change in version. Only other update made at the same time was Luxrender 1.3.1 to 1.5.1 so a pretty isolated change.
Well, yes, maybe Blender 2.76 started calling a broken CUDA function that it didn't call before, but that doesn't change the fact that the CUDA function itself is broken.
After all, if you never used a button in Blender before, but when you tried it in a new workflow it crashes, the bug is not in your workflow ;)
On non-DOS systems, the CPU and OS make it impossible for userspace software like Blender to cause a BSOD, it must be caused by either a hardware fault or a buggy driver (and allowing non-privileged software to crash the system is a pretty serious driver bug).
Fair point Lukas - I have pretty dim view of windows software models and their robustness - but haven't programmed at low level as kernel or graphics driver for a long time (so long I'm not going to admit how far back it was :-) - but certainly the model then allowed programs to quite easily elevate their privileges to a very damaging level )
Added subscriber: @mont29
Archiving for now, this is indeed most likely yet another GPU driver bug - and in any case, we cannot investigate something we cannot reproduce… :/
Added subscriber: @realman
ON MY PC
@realman please uninstall all GPU drivers from your computer (Intel, Nvidia, AMD) and install the latest drivers from your manufactures website. (This worked for me)
Oklet me try that and i'll let you know the result.
and thanks for the reply
done everything but nothing helps
and at last i tried as this link said
http://www.deskdecode.com/kernel-security-check-failure-0x00000139/
now my computer wont even open as normal
need some new suggestions
Added subscriber: @janifermagi
This comment was removed by @janifermagi
Added subscriber: @majyuet
This comment was removed by @majyuet
Added subscriber: @brecht
Added subscriber: @rohan8652
This comment was removed by @rohan8652
Added subscriber: @hiphoper722
This comment was removed by @hiphoper722
Added subscriber: @harissiam
Changed status from 'Archived' to: 'Resolved'
This comment was removed by @harissiam
Added subscriber: @jesterking
Added subscriber: @rohanrajpal
Changed status from 'Resolved' to: 'Archived'
Don’t why we have so many spammers on that page… will make it editable by admins only.
