bpy.props.StringProperty with subtype 'BYTE_STRING' loses information
Closed, InvalidPublic
Blender 2.76b, Ubuntu 14.04
When saving bytes to a StringProperty, all the information after the first null byte is lost.
Example:
import bpy
TEST_BYTES = b'foo\x00\x00\x00bar'
str_prop = bpy.props.StringProperty(subtype='BYTE_STRING')
bpy.types.Scene.test_str_bytes = str_prop
bpy.context.scene.test_str_bytes = TEST_BYTES
print('{} not equal to {}'.format(bpy.context.scene.test_str_bytes, TEST_BYTES))
assert bpy.context.scene.test_str_bytes == TEST_BYTES
Sebastian Brachi (brachi) raised the priority of this task from to 90.
Sebastian Brachi (brachi) updated the task description. (Show Details)
Sebastian Brachi (brachi) edited a custom field.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Unknown Status.Jan 7 2016, 6:45 PM
Checked and this is a known limitation.
However you can use ID-Property API to access non-terminated byte strings.
ob["prop"] = b'hello\0world'
print(ob["prop"])
{F271974}Here's a patch to add a note in the api docs about it, as it might not be trivial to fix it.
