Rigid Body Final Mesh doesn´t behave correctly with boolean modifier and animations
Closed, InvalidPublic
OSX 10.11 intel core i5 Nvidia gtx 680mx
Happens also on Win32
Broken: 2.76b Tested also
When using animated meshes in conjunction with the boolean modifier. The rigido body system doesn´t behave as expected and doesn´t take into consideration the boolean modifier. This will be seen better in the example attached.
Thanks for the report, but here you are using an animated boolean, rigidbody does not support varying geometry at all… So no bug here, just unsuported feature.
