Windows DPI scaling breaks row interleaved stereo viewport #47174
2 Participants
Reference: blender/blender#47174
Windows 8.1 & Windows 10
Nvidia GeForce GTX 980
Broken: 2.76b
(but since this depends on windows, not on Blender, it's probably in earlier versions with stereo workflow, too)
Windows allows setting a scale factor for high-DPI displays, which leads to DPI-unaware application content being upscaled.
reference
When you change the scaling for these legacy applications, the client area of their windows is upsampled by a user-determined factor.
In Blender this results normally in a almost unnoticeable blurred appearance of the whole UI.
When using the stereo workflow with a row-interlaced viewport, the upsampling destroys the stereo effect, since one blender generated scanline does correspond to more than one pixel-line on the screen.
See attached image.
Enter "dpiscaling" at the command prompt in windows.
Change the slider in the "Display" message box to "Larger" and press "Apply"
Open Blender and switch to stereo view: check "Views" under "Render Layers", menu "Window/Set Stereo 3D" switch to "Interlace - Row Interleaved"
Switch to camera view (NumPad 0)
Mitigation:
You can switch off this behavior in Windows for Blender:
right-click on "Blender.exe/Properties", check "Compatibility/Disable display scaling on high DPI settings"
Solution:
(Should be a really small change)
Change the Blender application manifest on the windows build to "application is system DPI–aware ".
(If you want to be really fancy, you could make Blender fully DPI-aware by responding to DPI-changes with changing the Blender internal DPI setting, but I do not think this is necessary)
Added subscriber: @alfv
Added subscriber: @ideasman42
Blender can scale its own interface, so likely it just needs to be made DPI-aware (as you suggest), then it can set its own scaling based on the system.
This a bug, moving to TODO.
