Modules not exported by game_engine_publishing.py #47239
Closed
opened 2016-01-26 02:48:17 +01:00 by Philippe · 8 comments
Linux 3.13.0-68-lowlatency #111-Ubuntu SMP PREEMPT Fri Nov 6 19:08:04 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Intel GMA 5000
blender-2.76b-linux-glibc211-x86_64/
Can't attach any file, there are a lot of dependencies and the whole project is more than 150Mgs! But I got a hunch that this new exporter is not including any external python module..?
Color management: using fallback mode for management
BLT_lang_init: 'locale' data path for translations not found, continuing
connect failed: No such file or directory
Detected GL_ARB_texture_env_combine
Detected GL_ARB_texture_cube_map
Detected GL_ARB_multitexture
Detected GL_ARB_shader_objects
Detected GL_ARB_vertex_shader
Detected GL_ARB_fragment_shader
Detected GL_ARB_vertex_program
Detected GL_ARB_depth_texture
Detected GL_EXT_separate_specular_color
found bundled python: /home/px/tmp/tst/default/2.76/python
Python module can't be imported - object 'Menu', controller 'Python':
ImportError: No module named 'menu'
Error Totblock: 2
**System Information** Linux 3.13.0-68-lowlatency #111-Ubuntu SMP PREEMPT Fri Nov 6 19:08:04 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux Intel GMA 5000 **Blender Version** blender-2.76b-linux-glibc211-x86_64/ **Short description of error** **Exact steps for others to reproduce the error** Can't attach any file, there are a lot of dependencies and the whole project is more than 150Mgs! But I got a hunch that this new exporter is not including any external python module..? Color management: using fallback mode for management BLT_lang_init: 'locale' data path for translations not found, continuing connect failed: No such file or directory Detected GL_ARB_texture_env_combine Detected GL_ARB_texture_cube_map Detected GL_ARB_multitexture Detected GL_ARB_shader_objects Detected GL_ARB_vertex_shader Detected GL_ARB_fragment_shader Detected GL_ARB_vertex_program Detected GL_ARB_depth_texture Detected GL_EXT_separate_specular_color found bundled python: /home/px/tmp/tst/default/2.76/python Python module can't be imported - object 'Menu', controller 'Python': **ImportError: No module named 'menu'** Error Totblock: 2
Author
Author
Added subscriber: @xaccrocheur
Author
I forgot to add that said module(s) are working file within both blender and blenderplayer.
Of course, there IS a meny.py file :)
I forgot to add that said module(s) are working file within both blender and blenderplayer. Of course, there IS a meny.py file :)
Added subscriber: @Sergey
First of all, your installation seems to be somewhat broken. This should not happen with official builds from builder.blender.org.
Please make sure you've fully downloaded and unpacked the archive.
Second of all, it's not a support system but a bug tracker, so you have to provide .blend which demonstrates the issue, otherwise we aren't able to troubleshoot it. Keep it as simple as possible.
First of all, your installation seems to be somewhat broken. This should not happen with official builds from builder.blender.org. ``` Color management: using fallback mode for management BLT_lang_init: 'locale' data path for translations not found, continuing ``` Please make sure you've fully downloaded and unpacked the archive. Second of all, it's not a support system but a bug tracker, so you have to provide .blend which demonstrates the issue, otherwise we aren't able to troubleshoot it. Keep it as simple as possible.
Added subscriber: @mont29
Bastien Montagne self-assigned this 2016-02-05 15:20:51 +01:00
No news since one week…
Reference: blender/blender-addons#47239
