Bone child.worldPosition and world Orientation appear to be at least 1 frame off
https://www.youtube.com/watch?v=jAcOvsTf3Vc&feature=youtu.be
I am using
object.worldPosition = boneChild.worldPosition+(boneChild.worldOrientation*Vector(offset)) and the weapon should be 'locked' to the same
rotation and position relative to the bone parented object (red box 'Hand')
however it lags at least 1 frame behind for some reason
Note - I am using copy rotation in the armature that the 'Hand' object is bone parented to.
Jacob Merrill (blueprintrandom) raised the priority of this task from to Needs Triage by Developer.
here is a test file illustrating{F279081} the bug is in fact related to copy rotation
left = copy rotation = use mouse and you can see the lag
right = uses animation to swing arm = no lag
I worked around this using a callback
what it was, was I moved a object to a local point relative to a object moved by a constraint,
so the constraint updated after the logic loop, so I was always 1 step behind.
So I moved the same code
weapon.worldPosition = player['Hand'].worldPosition+(player['Hand'].worldOrientation*Vector([offset]))
weapon.world Orientation = player['Hand'].worldOrientation
into a pre_draw callback, and it works great now.
Aaron Carlisle (Blendify) closed this task as Archived.
Aaron Carlisle (Blendify) claimed this task.
This task is being closed because the BGE has been removed in Blender 2.8.
