cannot execute boolean operation (error message)
Closed, InvalidPublic
windows 10 pro
windows 10 proand nvidia geforce gtx 750 ti
Blender 2.76b
windows 10 pro
Worked:
cannot execute boolean operation error message,uncknown reason{F279290}
Szymon Warunek (szymi) set Type to Bug.
Szymon Warunek (szymi) created this task.
Szymon Warunek (szymi) claimed this task.
Szymon Warunek (szymi) raised the priority of this task from to Needs Triage by Developer.
i actually do not know the reason of this boolean problem,maybe the topology is wrong or something else
I do not believe this to be a bug.
You need to reexamine your mountain mesh. It appeared to have extra vertices and was not quite manifold (completely closed).
It is possible to make the boolean operation function with the meshes in this file.
@Ignatz (ignatz) is right. Thanks for the report but this is not a bug.
Lukas Toenne (lukastoenne) closed this task as Invalid.
@Ignatz (ignatz) is right, the mountain mesh is simply non-manifold, it actually prints errors accordingly. Simply "remove doubles" already fixes this.
