Particle hair textures do not work properly when "Emit From" option is set to "Verts" #47294
2 Participants
Reference: blender/blender#47294
Windows 7 64 Home, nVidia GTX 970
Broken: 2.76b
f337fea
When the "Emit From" option within a particle hair system is set to "Verts", textures for that particle system used to control settings such as density do not work properly. It seems the particle system does not accept UV mapping as an option and will default to generated.
Create an cube, subdivide it many times. Unwrap it and give it a new black texture, then paint some areas white. Add a particle hair system and enable "Advanced," set the "Emit From" option to "Verts." Add a texture to it via the particle system menu then add the previously made image to that texture, remember to set the mapping to use UVs. Set the influence to something usable like "Density." Make sure the texture is visible on the mesh either by entering texture paint mode and applying the image or by creating a material that uses that texture. By now it should be clear that the settings used for the particle texture do not apply correctly to the cube. At this point, go into the particle system and change the "Emit From" option to "Face." Now you should see how the hair particle system should properly use the texture information.
Added subscriber: @DoNotCare
Update: This problem extends into materials. Particle hair systems with "Emit From" set to "Verts" cannot have textures in materials use the UVs of the emitter mesh. Again, they appear to just default to generated coordinates. This is the case for both Cycles and Blender Internal renderers.
Added subscriber: @Sergey
Particle system has quite a few intrinsic issues now, which we'd better be solving by redesigning the whole thing addressing the core issues rather than trying to repair broken design further.
Thanks for the report, it'll definitely something to consider for the new system, but for now would consider it a TODO for until new particle system is laid down.
