The "Disconnect/Connect Hair" feature for particle hair systems does not work properly with "Use Modifier Stack" #47319
Reference: blender/blender#47319
Windows 7 64 Home, nVidia GTX 970
Broken: 2.76b
f337fea
The "Disconnect/Connect Hair" feature for particle hair systems does not work properly when "Use Modifier Stack" is enabled in the "Emission" panel.
Create a cube and add a subdivision surface modifier. Add a particle hair system and enable "Use Modifier Stack" in the "Emission" panel. Enter particle edit mode and comb the hair just enough so that it has a clear style. In the particle hair settings Click "Disconnect Hair" then "Connect Hair." The particle hair system will not return to normal as expected. Now repeat the process without "Use Modifier Stack" enabled, but before disconnecting and reconnecting the hair, temporarily disable the subsurf modifier. In this case it works as expected when the subsurf modifier is re-enabled.
I should note that very similarly, the particle hair system transfer feature runs into the same problem with the "Use Modifier Stack" option, even making it impossible to successfully transfer a particle hair system to an identical mesh. I may make a separate bug report for this if necessary and if time permits.
Added subscriber: @DoNotCare
Added subscriber: @mont29
Thanks for the report, but for now particle system is needing a full rewrite, so such issues are considered more TODOs for new system than actual bugs.
Added subscriber: @Forshu-2
