Project Paint - Unified Settings: Color
Windows 7 gt560; Windows 8.1 hd4000
Broken: (example: 2.69.7 4b206af, see splash screen)
Broken: 2.76 48fdd6
This little checkbox in Texture Paint mode, Project Paint has little bug. As description is saying "Instead of per brush color, the color is shared across brushes". If unchecked everything works fine. After checking this option, whenever you open painting widget like for eg, when you try to {F280405}scale brush with "F". Color below widget does not change.
Check Unified Settings : Color in Texture Paint mode, sample different colors and check if they change in painting widget.
Related Objects
Paul (rice) raised the priority of this task from to 90.
Paul (rice) updated the task description. (Show Details)
Paul (rice) added a project: BF Blender.
Paul (rice) edited a custom field.
Paul (rice) added a subscriber: Paul (rice).
Made a fix for this - P321, however its using hard coded color check.
Though it could be less hassle if there was a read-only color that could be read from the context.
Sergey Sharybin (sergey) lowered the priority of this task from 90 to Normal.Feb 9 2016, 11:21 AM
@Campbell Barton (campbellbarton), why not to go with this patch for until more global changes are done to the context?
