UV Map renaming bug in Cycles UV Map node #47380
2 Participants
Reference: blender/blender#47380
Windows 8.1, NVIDIA GeForce GTX 960
Broken: 2.76b
When you manually change the name of a UV map in the UV Maps panel in the Object Data context, Cycles´ UV Map node does not pick up the name change, and it gives an unwanted effect-for example, any texture applied through
the UV map appears as black.
Open new file. Create a cube. Assign a UV map in Object Data context. Assign new material to object (in Cycles). In Node window, add an Input/UV Map node. Select newly created UV map in UV Map node. In Object Data context, change UV map´s name. Change is not reflected in UV Map node.
Added subscriber: @andreu
Added subscriber: @brecht
I agree that we should do this ideally, but this kind of automatic renaming support was just never implemented. Not for the UV Map node but also not for any other kind of UV Map usage.
It would be good to support this but it's not considered a bug.
I agree it's not a bug strictly speaking. But, if you check most everywhere else in Blender's UI behavior, this kind of automatic name update for referenced items seems to be the norm.
