FBX EXPORT: no keyframes are appearing in the exported fbx when objects stays put, even though i have manually inserted keyframes #47457
Closed
opened 2016-02-17 11:40:09 +01:00 by Al Dobra · 16 comments
Windows 8, Quadro K2100M
Broken: 2.76b f33fea
I inserted keyframes with no movement but no keyframes are appearing in the exported fbx file
**Add a cube, do not move, rotate or scale, just insert keyframes one after the other in the timeline, say for the first 5 frames insert a keyframe without moving the cube.
Export as binary fbx. Import in back into Blender: you will see no keyframes on the imported fbx file.
pasted_file
pasted_file
nokeyframesfbx.fbx
nokeyframes.blend
**System Information** Windows 8, Quadro K2100M **Blender Version** Broken: 2.76b f33fea **I inserted keyframes with no movement but no keyframes are appearing in the exported fbx file** **Add a cube, do not move, rotate or scale, just insert keyframes one after the other in the timeline, say for the first 5 frames insert a keyframe without moving the cube. Export as binary fbx. Import in back into Blender: you will see no keyframes on the imported fbx file. ** ![pasted_file](https://archive.blender.org/developer/F283441/pasted_file) ![pasted_file](https://archive.blender.org/developer/F283443/pasted_file) [nokeyframesfbx.fbx](https://archive.blender.org/developer/F283439/nokeyframesfbx.fbx) [nokeyframes.blend](https://archive.blender.org/developer/F283440/nokeyframes.blend)
Author
Bastien Montagne was assigned by Al Dobra 2016-02-17 11:40:09 +01:00
Author
Added subscriber: @AlexDoso
Closed as duplicate of #47456
Changed status from 'Duplicate' to: 'Archived'
No bug here, just disable Simplify (set it to 0.0) if you want pure static 'animations' too…
No bug here, just disable `Simplify` (set it to 0.0) if you want pure static 'animations' too…
Author
actually the Simplify doesn't work then. With 0.00 i get no keyframe what so ever :(
pasted_file
anim.fbx
actually the Simplify doesn't work then. With 0.00 i get no keyframe what so ever :( ![pasted_file](https://archive.blender.org/developer/F283450/pasted_file) [anim.fbx](https://archive.blender.org/developer/F283453/anim.fbx)
When AllActions & NLA Strips are disabled, this is assumed to be a 'global scene animation' export scenario, useless animation is always stripped in this case.
If you want that kind of action to be kept, you must enable All Actions and/or NLA Strips options.
When AllActions & NLA Strips are disabled, this is assumed to be a 'global scene animation' export scenario, useless animation is always stripped in this case. If you want that kind of action to be kept, you must enable All Actions and/or NLA Strips options.
Author
okay, this is how i exported this time, and still no keyframes whatsoever
pasted_file
{F283459}nokeyframes.blend
okay, this is how i exported this time, and still no keyframes whatsoever ![pasted_file](https://archive.blender.org/developer/F283457/pasted_file) {[F283459](https://archive.blender.org/developer/F283459/anim1.fbx)}[nokeyframes.blend](https://archive.blender.org/developer/F283460/nokeyframes.blend)
Author
PS: i tried with
  1. All Actions and NLA Strips activated
  2. just All Actions activated
  3. just NLA Strips activated
no keyframes what so ever :(
PS: i tried with 1) All Actions and NLA Strips activated 2) just All Actions activated 3) just NLA Strips activated no keyframes what so ever :(
OK, with force start/end frame you get first/last keys, but indeed we should export all keys when simplify is disabled (note that you'll get one key per frame then, since we bake…).
Author
yeah, i know about the force start/end frame option, it is not enough for me right now, but i need to have a keyframe on every frame, even the object is not visually moving, for my exported fbx file (when simplify is 0.00)
This issue was referenced by blender/blender-addons@219e882b31
This issue was referenced by blender/blender-addons@219e882b3168669bb733dafcce10bb79d90e8002
Author
i just did copy all the code into my 2 files of the exporter, but still no keyframes whatsoever
untitled.blend
untitled1.fbx (with All actions)
untitled.fbx ( with NLA Strips)
i just did copy all the code into my 2 files of the exporter, but still no keyframes whatsoever [untitled.blend](https://archive.blender.org/developer/F283473/untitled.blend) [untitled1.fbx](https://archive.blender.org/developer/F283474/untitled1.fbx) (with All actions) [untitled.fbx](https://archive.blender.org/developer/F283475/untitled.fbx) ( with NLA Strips)
Author
actually it works like in the picture below. Thanks
pasted_file
actually it works like in the picture below. Thanks ![pasted_file](https://archive.blender.org/developer/F283523/pasted_file)
Reference: blender/blender#47457
