Registry entries missing
Windows 10 64 bit, Windows 8 64 bit
Broken: 2.76b f337fea
Worked: 2.74
Former versions of Blender created the registry node "HKLM/Software/BlenderFoundation" with key "Install_Dir" in it. The node is not created with version 2.76b any longer; neither by Blender's 64 nor the 32 bit version. Bad for me because my add-on's installer cannot find Blender's "addons" directory, and the user has to copy the script by hand now.
Uninstall your current Blender, double click on "blender-2.76b-windows32.msi" or "blender-2.76b-windows64.msi" and check the Windows registry for the node "HKLM/Software/BlenderFoundation". It is not there.
Friedemann Seebass (frisee) raised the priority of this task from to Needs Triage by Developer.
Friedemann Seebass (frisee) updated the task description. (Show Details)
Julian Eisel (Severin) lowered the priority of this task from Needs Triage by Developer to Normal.Feb 18 2016, 1:28 PM
LazyDodo (LazyDodo) closed this task as Archived.Dec 1 2016, 3:46 AM
the new msi installers indeed do not create those registry keys (as it is an artifact of the nsis (un)installer) they do however still register the .blend filetype handler, which you can use to track down the path of the blender installation. You can find this registry key at
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\blendfile\shell\open\command
