"Show Weights" in Edit mode does not work in conjunction with a "Vertex Weight Proximity" Modifier
i7, 16gb ram, ubuntu 64 51.10, 2*Gtx 560ti oc 2GB
Broken: Current git (4e95807 didn't track back when the change happened)
Worked: 2.76b
Weights don't show up in edit mode when one of the vertex weight modifiers are used. Visible in the attached pics:
Use the appended file
and hit alt + a - this should show you how a part of the mesh is getting more and more red. Instead, there is no weight visible at all. The same file acts correctly in 2.76b
Revisions and Commits
Thomas Beck (plasmasolutions) renamed this task from "Show Weights" in Edit mode does not work in conjunction with a "Vertex Weight Edit" Modifier to "Show Weights" in Edit mode does not work in conjunction with a "Vertex Weight Proximity" Modifier.
Thomas Beck (plasmasolutions) raised the priority of this task from to 90.
Thomas Beck (plasmasolutions) updated the task description. (Show Details)
Thomas Beck (plasmasolutions) edited a custom field.
Bastien Montagne (mont29) lowered the priority of this task from 90 to 50.Feb 21 2016, 9:54 PM
Can confirm the issue, would bet on a consequence of OpenGL changes, draw_mesh_paint_weight_faces seems to not drawing weights as expected?
