Painting depth of field effect in viewport
Ubuntu 14.04 x86_64 Linux 3.16.0-30-generic
Broken: 2.77 RC2 6a593ab
Worked: 2.76b f337fea
If you will move the focus object behind it draws plume scene blur
https://youtu.be/XqA1BgKiE9M
  1. Enable "Depth of Field" in viewport
  2. Switch to view from camera
  3. In "Depth of Field" section of Camera Settings select Focus object
  4. Move object in front of the camera and watch at the strange blur trail behind it.
my369@yandex.ru (acvarium) created this task.
my369@yandex.ru (acvarium) raised the priority of this task from to Needs Triage by Developer.
Campbell Barton (campbellbarton) triaged this task as Needs Information from User priority.
Cant redo the error, can you confirm if this happens when grabbing the empty in this file
If not, please upload a blend file which can be used to reproduce the error.
Also, could you attach system info?
https://www.blender.org/manual/getting_started/help.html#save-system-info
I did some experiments with this file and the various versions of Blender since 2.74.
The problem turned out to be wider and more mysterious than I expected.
https://youtu.be/33IZRu1RP8Q
https://youtu.be/tEk8S2FMBlg
I understand that this is likely to blame for my video driver, but still hope that the solution will come from your side.
I have nvidia gtx 870m and use driver version 331.38, because so far I have less problems with it.
This isn't reasonable to expect, of course workarounds may be possible, but if this is a driver bug and developers can't redo. its unlikely we can work-around it.
Campbell Barton (campbellbarton) raised the priority of this task from Needs Information from User to Normal.
Aaron Carlisle (Blendify) closed this task as Archived.
Aaron Carlisle (Blendify) claimed this task.
Closing due to lack of activity.
