Discontinuity (Euler) Filter needs a bit of help #47554
6 Participants
Reference: blender/blender#47554
Windows 7 Professional
NVIDIA 960
Broken: 2.76b
"Discontinuity (Euler) Filter" yields a result that still has discontinuity that in some discontinuous areas requires resultant sections of keyframe values to be inverted (in value over 0) before being manually re-positioned in value (offset in increments of 180 degrees) before actual continuity is achieved.
Running the "Discontinuity (Euler) Filter" on the "DiscontinuousEulers_Before.blend"DiscontinuousEulers_Before.blend file (attached) yields "DiscontinuousEulerFilter_Applied.blend" DiscontinuousEulerFilter_Applied.blend file (attached)
*Long description of error
Working with mocap data that has been "baked across" between riggings with World coordinates yielded the "DiscontinuousEulers_Before.blend" on a character's hand. (Actor was dancing intensely)
(It seems like Axis Flipping occurred whenever any axis crossed a 90 degree mark?)
Applied "Discontinuity (Euler) Filter" on XYZ rotations to yield "DiscontinuousEulerFIlter_Applied.blend"
"Discontinuity (Euler) Filter" looks like it does a great start at untangling discontinuous Eulers, but needs to be "plussed" to watch for sections of keys that jump in increments of 180 degrees from one frame to the following frame that need to be raised or lowered to link up to preceeding keys... ...and to watch for sections of keys that jump in increments of 90 degrees from one frame to the following frame that I've seen indicate a section of keys that need to be inverted (eg: "Mirror by Values over Value ___") in value before they can be shifted-in-value in 180 degree increments to yield continuous Euler curves. (eg: Frames 407-432 in "DiscontinuousEulerFIlter_Applied.blend", which must have the X and Z values in that range shifted in value by -180... but the Y VALUES be Key > Mirror > By Values over Value = 0, before having their values shifted by -180 before the curves in that section link up with preceeding keys and also yield the original action.)
Added subscriber: @Albee
Added subscriber: @JoshuaLeung
Indeed, the Euler Filter could do with some improvements to deal with problems like this better. Checking the code, it is a known problem that the current method is too crude to cope with some situations like this.
Marking as todo for now, since this isn't a new issue/regression.
Added subscriber: @iurimonteiro
I have lots of euler problems and problems with quaternion rotations in blender 2.8
Added subscriber: @StanislavOvcharov
Added subscriber: @MarcelLegindi
The 'new' implementation of the Euler filter in
e4ca1fc4ea
seems to have fixed this.
