Incorrect Image
Figure 22 in the Parent section of the Blender Manual is Incorrect. It does not show what was described in the manual:
To check weather a particular bone in an armature is a Deforming Bone simply switch to Pose Mode or Edit Mode on the armature and select the bone you are interested in by RMB it. Once the bone of interest is selected navigate to [Properties Editor > Bone Context > Deform Panel] and check if the Deform tickable option is ticked or not. If it is the selected bone is a Deforming Bone, otherwise it is a Control Bone. See figure 22.
https://www.blender.org/manual/editors/3dview/object/relationships/parents.html#armature-deform-with-automatic-weights
Turki Yanksar (tyanksar) raised the priority of this task from to Confirmed, Low.
Turki Yanksar (tyanksar) updated the task description. (Show Details)
Turki Yanksar (tyanksar) set Type to To Do.
Refer to the Blender 2.76 Manual --> Editors --> 3D --> 3D View --> Relationships --> Parenting Objects --> Armature Deform Parent
Can you please tell us what is incorrect about the image. Thanks
Aaron Carlisle (Blendify) raised the priority of this task from Confirmed, Low to Needs Information from User.
Aaron Carlisle (Blendify) updated the task description. (Show Details)
Aaron Carlisle (Blendify) changed Type from To Do to Bug.
Aaron Carlisle (Blendify) raised the priority of this task from Needs Information from User to Normal.Feb 28 2016, 3:53 PM
Aaron Carlisle (Blendify) renamed this task from Figure 22 in the Parent section of the Blender Manual is Incorrect. to Incorrect Image.Mar 1 2016, 6:30 PM
Hi there, can I contribute to this as part of my coursework?
Sure just simply submit a picture in this task.
Notes. for screenshots:
  • use default theme, zoom level.
  • avoid window borders.
