Improper or Sub-optimal Lighting Results with Clamp Direct (Cycles) #47746
2 Participants
Reference: blender/blender#47746
Windows 7 64 Home, nVidia GTX970
Broken: 2.76b Win 64 (
f337fea
), 2.76.11 (2.77 Test Build 2 Win 64) (da81227
)Short description of error
I realize that "Clamp Direct" is not intended to give accurate results, but from my testing, it seems to give VERY inaccurate results:
The "Clamp Direct" sampling setting may not be calculating light received by objects properly/optimally. When "Clamp Direct" is set to a low value such as 3, light from a weak lamp will override/weaken the light from a stronger lamp when received by an object.
Here is a render from the attached .blend when using a bright white emitter mesh.
And here a weaker emitter mesh is enabled. The other emitter mesh is still enabled.
Improper_or_Sub-optimal_Lighting_Results_with_Clamp_Direct.blend
Open the attached .blend and check the text file within. I will repeat the instructions written here:
Set the veiwport display mode to Rendered. The lit area of
the sphere object should appear mostly pure white. Next,
enable visibility of the object "EmitterPlane.Blue". This
should result in a drastically reduced amount of light on
the sphere object. Final renders yeild the same result.
Added subscriber: @DoNotCare
Added subscriber: @brecht
It's not a bug, clamp direct / indirect are options that you use as a last resort hack to reduce noise, 3 is a very low value to use especially for direct light. The result of clamping is scene dependent, if you use multiple lights individual AA samples are noisier, which means the samples have higher values and more light gets clamped away, and the result is darker.
