Motion curve update mismatch #47762
Reference: blender/blender#47762
Windows 7 Professional 64-bit SP1
Nvidia GeForce GTX 760
Broken: Blender 2.75a ...up to and including current version... 2.77 rc2
Description: When moving a keyframe from within the dope sheet editor the movement of the keyframe within the graph editor does not reflect the true condition of the new curve until the action is finished.
This is a small visualization bug.
It will be seen that when a keyframe is moved in time (along the X axis) from within the graph editor the keyframe handles as well as the associated curve will change as required during the move to constantly reflect changes related to the new position of the keyframe.
When the keyframe is moved from within the dope sheet editor the keyframe will also move within the grpah editor, but the simultaneous updating of handle length and correct curve shape will not be shown. However, when the action is completed, the curve and handles in the graph editor will update to reflect the new, correct position.
curve update visualization.blend
Added subscriber: @ignatz
Added subscriber: @mont29
Joshua, think this one is for you? ;)
Technically, this is not really a bug; it is however a glitch that we know about AND have thus-far decided against fixing.
This issue happens because the when transforming keyframes in the Action Editor, we do not rearrange the actual order of the keyframes in the FCurves until the transform is done. We could do so (and it is done for the Graph Editor, because it has to be done as the curves are visible), though so far, the cons of doing so outweight the pros.
Pros:
Cons:
3) Slower keyframe editing in Action Editor
4) Significantly more complicated (i.e. really convoluted, hard to maintain, head-scratching + confusing) code needs to be in place to track and remap the "transvert" pointers to refer to the correct keyframe point values, as reordering the keyframes while transforming will constantly invalidate the old mappings. (Note: Although similar code has been created for the Graph Editor, the differences between the two are significant enough that a separate set of code for this will be needed instead)
5) Making these changes is unnecessary when considering the intended use cases of these editors - The Action Editor is used mainly for blocking animation and broad/coarse timing corrections, while Graph Editor is for fine tuning value change over time in "polish" passes (where timing changes less).
So, overall, IMO it's better that we don't try going in fixing this, as it doesn't seem to be worth it. One or two particular feature changes may warrant a review of this, but until then, I think the current behaviour should be fine.
Thanks for the report anyway :)
