Rendering Crash, Node Connector Crash, Changing Editors Crash
Blender 2.77 rc 2 Crash Bug Report Info
CPU: Intel® Core i7-4710MQ CPU @ 2.50GHz ×8 64 bits
RAM: 11 GiB
GFX: Intel Haswell Mobile 4th Gen Core Processor Integrated Graphics Controller
OS: Ubuntu 14.04.4 LTS
Kernel: 3.16.0-51-generic #69~14.04.1-Ubuntu
Broken: (example: 2.69.7 4b206af, see splash screen)
Broken: Blender: 2.77 rc 2
Date: 2016-03-04 17:08
Hash: 1e1118e
Worked: Blender 2.76b on the same platform
1: Clicking on 'Animation' to render the composite crashes Blender immediately.
2: Moving a node connector to another node immediately crashed Blender.
3: Changing from the Text Editor to the Node Editor resulted in an immediate crash of Blender.
Initial problem: Clicking on 'Animation' to render a composite crashed Blender immediately.
Diagnostic follow-up stage 1: Try to diagnose by simplifying composite. Attempt to find where in the composite the error was occurring by removing parts of the composite. Sorry guys, I tried to work this down to the simplest node tree possible but that created another problem.
Stage 1 Result: Unable to change node hookup without Blender crashing.
			      Change connectors to directly connect the occupied node sockets of the two nodes marked by the nearby red frames.
			      Trying to do so crashes Blender.
Navigating Between Editors: Changing from Text Editor to Node Editor by clicking on the icon menu in the lower right corner of the UI pane resulted in an immediate crash.
See:
George Muhs (oldskoolvfx) set Type to Bug.
George Muhs (oldskoolvfx) created this task.
George Muhs (oldskoolvfx) raised the priority of this task from to Needs Triage by Developer.
Thank you for your suggestion.
I downloaded the following:
blender-2.77-861616b-linux-glibc219-x86_64
The following still exist:
This did not repeat:
A new issue showed up:
4: Automatic rendering by opening or shifting to the node editor crashed Blender. The older version of Blender associated with the original bug did not render automatically although all the setting where set to do so as the newer version did prior to crashing.
Thanks.
Thanks.
