Alt+F9 shortcut doesn't hide the header
Windows 7 - Quadro 4000
Broken: 2.77rc2 hash 1e1118e
Worked: Blender 2.76
The shortcut Alt+F9 doesn't hide the header in the last RC2 of Blender although the shortcut in the input preferences is correctly set for screen.header the same way as the 2.76 version.
Open Blender, press Alt+F9.
Vincent Girès (VincentG) set Type to Bug.
Vincent Girès (VincentG) created this task.
Vincent Girès (VincentG) raised the priority of this task from to Needs Triage by Developer.
Campbell Barton (campbellbarton) triaged this task as Needs Information from User priority.
Do you mean Alt-F10? Alt-F9 isnt assigned to anything.
Assuming it is, I cant redo the error in 2.77rc2 or master.
Does this happen on the default startup.blend? if not please submit the blend-file which shows the error.
Yes this is with the default startup.blend.
Alt+F9 is assigned to hide/show header since Blender 2.73: https://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.73/UI 7c25f16f1ac4b68
