Vector property subtype DIRECTION error - driver add, zero value #47826
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#47826
Broken: (All)
Worked: (None)
Normal.blend
open this file, run script "normal" - we will have proper panel with custom property
run "fade to zero" - we will set (0,0,0) and can not change it by interface
run "set any other" - we will set not equal(0,0,0), and then can change this property by interface
repeat it with driver add/remove/set any other
Added subscriber: @Inwader77
Added subscriber: @Sergey
If i understood you correct then it's not really a bug. Thing here is that in interface you're operating with direction and in order to change it you need to know the direction. However, value of
(0, 0, 0)
is a zero-vector which is a malformed direction. Changing any of the components to a non-zero solves the ambiguity and allows to properly operate with that direction.Thanks for the report, but i don't really see a bug here so far.
