Blend File Utils fails with any .blend file
Closed, DuplicatePublic
OS X 10.10.5, AMD FirePro D500 3072 MB
Broken: 2.77 release
Blend File Utils fails to create an Archive from a Blend file
Any .blend file I tried will do, even one that has 1 cam, 1 sun lamp, 1 null and 1 cube.
Enable the addon.
Use it as directed.
Note that no ZIP is created.
Look in Info window in blender and see:
SyntaxError: can not delete variable '_src_dir' referenced in nested scope
Moon Caine (mooncaine) raised the priority of this task from to 90.
Moon Caine (mooncaine) updated the task description. (Show Details)
Moon Caine (mooncaine) edited a custom field.
mangostaniko added a subscriber: mangostaniko.EditedMar 30 2016, 2:14 AM
What is your Python version?
e.g. Help -> Save System Info, then just drag the file into the comment text field here to upload.
This should be a limitation removed as of Python 3.2.
https://stackoverflow.com/questions/12338713/python-nested-scopes-with-dynamic-features
If a variable is referenced in an enclosed scope, it is an error to delete the name. The compiler will raise a SyntaxError for 'del name'.
In io_blend_utils/blendfile_pack.py, lines 380–386:
https://developer.blender.org/diffusion/BA/browse/master/io_blend_utils/blendfile_pack.py;e42f47d181a4d725b95200fd33d873fc85be6704$380-386
Then however Blender 2.7x should need Python 3.5 anyway?
Thanks, issue is actually with blender on OSX reporting a wrong python executable path… merged in original report.
