Constraint influence driven by bone doesn't work. #48231
Closed
opened 2016-04-21 21:09:07 +02:00 by Mario Mey · 11 comments
Linux, Ubuntu-Mate 14.04, nVidia GT620
Broken: 2.77 (from page)
There's a bone with Action Constraint that its influence is driven by another bone. In normal play (Alt-A), the constraint is well driven (it goes to 0). But when entering in game engine, it doesn't do the same, the Influence is still at 1.
Open the file, play the animation with Alt-A
Enter in BGE, the animation plays automatically.
Compare the movement of the bone "B" in both situations.
Here I use Action constraint, but I think that this happens also in other constraints.
90-action-const-influence.blend
**System Information** Linux, Ubuntu-Mate 14.04, nVidia GT620 **Blender Version** Broken: 2.77 (from page) **Short description of error** There's a bone with Action Constraint that its influence is driven by another bone. In normal play (Alt-A), the constraint is well driven (it goes to 0). But when entering in game engine, it doesn't do the same, the Influence is still at 1. **Exact steps for others to reproduce the error** Open the file, play the animation with Alt-A Enter in BGE, the animation plays automatically. Compare the movement of the bone "B" in both situations. Here I use Action constraint, but I think that this happens also in other constraints. [90-action-const-influence.blend](https://archive.blender.org/developer/F304722/90-action-const-influence.blend)
Author
Author
Added subscriber: @MarioSottile
Author
Maybe this is an oooold known system limitation... that I reported in 2010 (#22850)?
If yes... I'm really sorry, delete this report now!
Maybe this is an oooold known system limitation... that I reported in 2010 (#22850)? If yes... I'm really sorry, delete this report now!
Added subscriber: @Sergey
Sergey Sharybin self-assigned this 2016-04-22 18:17:24 +02:00
You can not use a bone to drive something inside of the same armature, it's unsupported by the current dependency graph. We're working on solving limitations like that in a new system.
So thanks for the report, but it's not a bug.
You can not use a bone to drive something inside of the same armature, it's unsupported by the current dependency graph. We're working on solving limitations like that in a new system. So thanks for the report, but it's not a bug.
Author
@Sergey, are you talking about Blender or the Game Engine?
Those behave in a similar way.
Author
@Sergey, why do you say that we can't drive something inside of the same armature? The file I uploaded here does not work in BGE, but it does in Blender (and shows no error messages).
That's why I asked you if you were talking about Blender or BGE.
@Sergey, why do you say that we can't drive something inside of the same armature? The file I uploaded here does not work in BGE, but it does in Blender (and shows no error messages). That's why I asked you if you were talking about Blender or BGE.
I say that because i know how current dependency graph and pose solver works, apparently.
The issue here is that with current dependency graph pose bones gets sorted for evaluation based on their parent and constraint targets, without taking drivers into account. In fact, currently drivers are only evaluated once per all bones. This makes it so your armature might or might not be updated correct. It all depends on memory addresses and phase of the Moon. It's really something you can't predict.
Proper thing to do here is to sort bones for evaluation based on all drivers, constraint targets etc etc. it's something we do in the new dependency graph (enabled with --enable-new-depsgraph command line argument). However, new depsgraph is not fully finished and not hooked up to all the subsystems and some more work needed there.
I say that because i know how current dependency graph and pose solver works, apparently. The issue here is that with current dependency graph pose bones gets sorted for evaluation based on their parent and constraint targets, without taking drivers into account. In fact, currently drivers are only evaluated once per all bones. This makes it so your armature might or might not be updated correct. It all depends on memory addresses and phase of the Moon. It's really something you can't predict. Proper thing to do here is to sort bones for evaluation based on all drivers, constraint targets etc etc. it's something we do in the new dependency graph (enabled with --enable-new-depsgraph command line argument). However, new depsgraph is not fully finished and not hooked up to all the subsystems and some more work needed there.
Author
When I just finished writing the report, I realized that I reported the same issue 5 years ago. Because of this, I forgot to say that when I did this file, I was using the new depsgraph (*). And yes, as I said in the report (and you deducted), with new depsgraph, this configuration does work...
But it does in Blender, not in BGE. Is there any plan to make it work also in Game Engine?
Understanding that this is the way the current depsgraph works and having in mind that the new one is still in development, we can close this report.
Thank you.
(*) I'm working with new-depsgraph for some time because it fixes some dependencies cycles that I had in my files. Also, I want to test it (I've already reported some bugs about this).
When I just finished writing the report, I realized that I reported the same issue 5 years ago. Because of this, I forgot to say that when I did this file, **I was using the new depsgraph (*)**. And yes, as I said in the report (and you deducted), with new depsgraph, this configuration does work... **But it does in Blender, not in BGE.** Is there any plan to make it work also in Game Engine? Understanding that this is the way the current depsgraph works and having in mind that the new one is still in development, we can close this report. Thank you. --- (*) I'm working with new-depsgraph for some time because it fixes some dependencies cycles that I had in my files. Also, I want to test it (I've already reported some bugs about this).
2 Participants
Reference: blender/blender#48231
