rotate edges local-global not working
Closed, InvalidPublic
Caption : Microsoft Windows 10 Home
OSArchitecture : 64-bit
DeviceID Name DriverVersion
VideoController1 NVIDIA GeForce GT 740M 10.18.13.6191
VideoController2 Intel(R) HD Graphics 10.18.10.4276
Broken: (example: 2.69.7 4b206af, see splash screen) Blender 2.77a
Worked: (optional) yes Blender work
The Operator tab to rotate is show/rendered after I make one simple mouse move.
The rotate of edges not working - same effect of rotation local and global ( I don't test all of this options).
  • make one cylinder , go to edit edges ;
  • select some edges with Edge Rings ;
  • try to rotate to make some bladed propeller at an angle by rotating edges;
Bastien Montagne (mont29) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Apr 22 2016, 10:29 PM
Please follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
Please seek user support on user forums like blenderartists.org or blender.stackexchange.com.
Ok, then what you want is to change Pivot Point to 'individual origins' (third dropdown menu after mode and viewport shading, in 3DView header). Transform orientations (spaces) have nothing to do here.
Anyway, no bug, closing.
even that , the rendered area of transform orientations view come after move the mouse , I don't know why ?
