Rigify : toe not snapped on fk2ik Snapping when foot is rolled #48286
Closed
opened 2016-04-27 08:22:05 +02:00 by Julien Duroure · 6 comments
Member
Ubuntu 14.04
Broken: 2.77a
  • Open attached file
  • Click on "Snap FK->IK (thingh.fk.L)
  • Slide FK/IK (foot.ik.L) to 0.0 (FK)
    • toe is moving
bug_snap.blend
PS : Attached file is done by following steps :
  • Enable Rigify addon
  • Add Rigify metarig
  • Generate Rigify Rig
  • Delete metarig
  • switch to Pose mode
  • select foot_roll.ik.L
  • Change L leg to IK mode
  • Display DEF bone layer
  • rotate roll bone
**System Information** Ubuntu 14.04 **Blender Version** Broken: 2.77a Worked: (optional) **Short description of error** Rigify : toe not snapped on fk2ik Snapping when foot is rolled **Exact steps for others to reproduce the error** * Open attached file * Click on "Snap FK->IK (thingh.fk.L) * Slide FK/IK (foot.ik.L) to 0.0 (FK) - > toe is moving [bug_snap.blend](https://archive.blender.org/developer/F307244/bug_snap.blend) PS : Attached file is done by following steps : * Enable Rigify addon * Add Rigify metarig * Generate Rigify Rig * Delete metarig * switch to Pose mode * select foot_roll.ik.L * Change L leg to IK mode * Display DEF bone layer * rotate roll bone
Author
Member
Author
Member
Added subscriber: @JulienDuroure
Added subscriber: @mont29
Nathan Vegdahl was assigned by Bastien Montagne 2016-04-29 12:45:49 +02:00
Assigning to Nathan, not sure this addon is still maintained though…
Nathan Vegdahl was unassigned by Julien Duroure 2017-01-23 11:03:24 +01:00
Ivan Cappiello was assigned by Julien Duroure 2017-01-23 11:03:24 +01:00
Author
Member
Added subscriber: @cessen
Member
Reference: blender/blender-addons#48286
