Please make Blender capable of automatically recognize the Linux desktop PPI, and set it to its interface accordingly.
Related Objects
- Mentioned In
- T55370: Linux todo list
Even though X11 has a DPI setting for the viewport, it seems each desktop environment/widget set uses its own scaling. see: http://www.makeuseof.com/tag/linux-hidpi-support-for-gnome-kde-xfce-cinnamon-and-firefox/
We could...
- Read the DPI settings from X11 and guess, while this should work, it seems nobody is using this setting to scale the UI, so likely its not a reliable value.
- Read the interface scale setting from gnome/kde... etc (not very portable).
However it would be good if there was some more straightforward way to get this information from X11/xlib.
Seems than your point is right, and the only way to configure that right now is per desktop environment.
Where do you think I should ask for this feature to be implemented?
Ideally this is something https://www.freedesktop.org would have a specification for. (maybe worth asking on their mailing list... )
I have just started a conversation about it on the Freedesktop mailing list. As soon as we get some conclusion, I will post it here.
Thank you.
In the Wayland display manager this can be achieved by using (https://wayland.freedesktop.org/docs/html/apa.html#protocol-spec-wl_output).
I'm going to ask for xserver and mir.
In the Mir display manager this can be achieved by using (https://unity.ubuntu.com/mir/struct_mir_display_output.html).
@ Campbell Barton
Since the feature can be implemented in at least two of the three existing display servers, please consider reopening this bug report again. Thanks
xserver also has a way to do so: (https://lists.x.org/archives/xorg/2016-May/058039.html)
The most generic solution might be Xft/DPI from XSETTINGS:
https://www.freedesktop.org/wiki/Specifications/XSettingsRegistry/
This is mostly a GNOME / GTK thing, but from what I can tell this is what Chrome and Firefox use (though GTK) on all desktop environments. It should also work with KDE through xsettings-kde and Xfce through xfsettingsd.
