Black image
Closed, InvalidPublic
2.77
Broken: (example: 2.69.7 4b206a{F307335}f, see splash screen)
Hi, I'm new to blender and today I was doing some tests and I spend something that I did not find solution ...
What happens is that when you press the 0 to have the view of the camera and then press the F12 to get the picture , the image comes out of black color ... that's a mistake ? or I pressed something wrong ?
Thank you.
sorry for the English , I'm using google translator
Matias (Slayermago) set Type to Bug.
Matias (Slayermago) created this task.
Matias (Slayermago) claimed this task.
Matias (Slayermago) raised the priority of this task from to Needs Triage by Developer.
Did you add lights? Is there any ambient world lighting (that'll be under the Earth icon in the properties panel)? Which render engine; Cycles or Blender Internal? Graphics Card or CPU render, if in Cycles?
Try, under File, to click on "Load Factory Settings" as well.
Campbell Barton (campbellbarton) closed this task as Invalid.
Bug reports need to be software errors we can reproduce.
This is more of a support question and most likely problem with the scene settings,
best ask questions like this at: http://blender.stackexchange.com
closing.
