Scalar Group Node Output is One Pixel Large #48297
7 Participants
Reference: blender/blender#48297
uname -r: 4.3.0-1-amd64
Debian 8 testing (sid)
Broken: 2.77a (official tar'ed build from blender.org)
My compositing node system relies extensively on nodegroups, sometimes nested several layers deep. Sometimes, these nodegroups need to process not a bitmap, but simply an individual scalar value - which might be inputted using the RGB node, or the Value node. It's when outputting a scalar from a nodegroup that it breaks; the output value is a bitmap that is one pixel large.
I suspect that any person or studio interested in creating a nested node system for their own ease of use will run into this issue!
Load compositing scene.
Create 2 Math nodes. Put each in its own nodegroup.
Let each nodegroup have one input and one output, passing through the Math node's first input within each group. In both cases set the Math node to Multiply, and the second input to 1.
Pass in the value 1 for the first nodegroup, and let the output of nodegroup 1 become the input of nodegroup 2.
Find any image, and plug it into the first input of a color Multiply node. In input 2, plug in the output of nodegroup 2.
Notice as a single pixel in the image remains unchanged, as the rest of the image becomes black.
I attached screenshots to better illustrate the setup:
Added subscriber: @Darkfie9825
#93013 was marked as duplicate of this issue
Added subscriber: @mont29
Huummm, seems to have been solved since 2.77a? I cannot confirm that with latest master here, please try the latest build from our buildbot. Otherwise, please attach a .blend, much simpler for us to reproduce and investigate.
Aha! It's a bug with the Buffer Groups option! Bug hunting is fun...
I'll provide a blend:
bug.blend
Turn off Buffer Groups and recomposite, and it'll work perfectly. Turn it back on, and there'll be a single pixel glaring at you!
I tested this with the latest (4AM) build as well; the bug persists.
Added subscriber: @Sergey
Added subscriber: @Jeroen-Bakker
@Jeroen-Bakker, there are two issues here:
First issue is probably not so hard, but second one i couldn't really fix today and wouldn't mind having some debuging from you ;)
Issue seems likely to be caused by ##MathBaseOperation::determineResolution##
it first checks if there are is a connection what can be marked as being important. This is done by determining the resolution with using a dummy preferred resolution of ##(0,0)##.
The Multiply node caches this resolution for next calls. and therefore also returns this. When ##0,0## is returned it is set to ##1,1## by ##WriteBufferOperation::determineResolution##
When commenting out the code at ##MathBaseOperation::determineResolution## the issue is solved, but it impacts the functionality of the node (determining the right output resolution). We need to see how we can really check what path determines the correct output resolution.
This part is also implemented by the ##MixBaseOperation##. Could not find other nodes with this implementation.
We propose that we add a boolean to the ##NodeOperation::determineResolution## method ##bool cache=true##. In the ##MixBaseOperation## and the ##MathBaseOperation## we set cache to false. This way we get the answer we want without influencing the rest of the system. Also need to change the setResolution for this one.
@Sergey, what do you think about this solution?
Not really fan of that. It's just some corner-case complication over the system which is already really unclear. Unless you can come up with really strict rule of how
determineResolution()
should behave, when to cache and when not i;m not really fan of such hacks.Why can't we just change fallback resolution to
(1, 1)
? Or if some nodes really don't need to cache resolution, overload theirisResolutionSet()
?Also, be aware that resolution is is caching for a reason -- with a complex enough nodes setup it might take forever to calculate resolution, since this part of the code is actually an exponential complexity.
Added subscriber: @DoomScream
Removed subscriber: @DoomScream
Added subscribers: @RealJayJobes, @lichtwerk
