Mirror vertex group can't work normally in the edit mode #48387
Reference: blender/blender#48387
windows 7 64bit sp1
Broken: 2.77a
abf6f08
Mirror vertex group can't work normally in the edit mode, but in weight paint mode is worked.
Mirror vertex group in the edit mode have lots problem, some like:
If the vertex in the vertex group not selected, the Mirror vertex group will not work, and will report 0 vertices mirrored, xxxx failed.
If the vertex in the vertex group have selected, the Mirror vertex group will reportxxx vertices mirrored, xxxx failed. but when you press A deselect all vertex, and than press "select" button in the vertex group pannel,you can find it's will select original vertex, not mirroired, and if you switch to weight paint mode, you can find no weight in the group
if you mirror the vertex group in the weight paint mode, the mirror vertex will work, but when you switch to the edit mode, than press "select" button, and you can find ,it's not right.
I have tried this in day build version, it's still not right, and I record one gif, you can get at below, hope can help you, sorry for my bad english.
Added subscriber: @Leroy-Xie
There was an error reporting the number of failed verts,
fixed
299a25cb35
.Further, this is working as expected.
If you want to copy one side to another. you can select half of the vertices with: "Select -> Side of Axis" menu item.
closing.
Hi, very thanks for you fix this, and I still have some question, does this have fix in the day build version? I am meaning the "select" button is use to select the vertex in current vertex group, but the selected vertex in the edit mode not same as the weight paint mode, is this right. something like in the flow images, sorry for my english
Changed status from 'Archived' to: 'Resolved'
This issue was referenced by
c1e4aaa289
