Armature Symmetrize is flipping Custom Shape parameter
When you run the armature symmetrize operator in edit mode, in some cases it mirrors the "custom shape at:" parameter. If I'm not wrong that's the custom_shape_transform property. So, if there was a _R bone in that field, it is mirrored to _L.
I'm attaching a blend file
Procedure:
_Open Blend
_Go to Edit mode
_Select Bone_L and Bone_R
_Run armature symmetrize operator
_In pose mode you will see that the bone shapes of both bones have moved to Bone2_R, when the _L bone should have stayed with the Bone2_L address.
In this file this only happens if you select the 2 bones I mentioned. If you select all 4 bones, the bug does not occur.
Juan Pablo Bouza (jpbouza) created this task.
Juan Pablo Bouza (jpbouza) raised the priority of this task from to Needs Triage by Developer.
Damn, typo in the title, I meant "flipping parameter"
Bastien Montagne (mont29) renamed this task from Armature Symmetrize is slipping Custom Shape parameter to Armature Symmetrize isflipping Custom Shape parameter.
Bastien Montagne (mont29) renamed this task from Armature Symmetrize isflipping Custom Shape parameter to Armature Symmetrize is flipping Custom Shape parameter.
Bastien Montagne (mont29) triaged this task as Confirmed, Medium priority.
