different order of face vertices indexes between 2.76b and 2.77a #48444
Closed
opened 2016-05-15 20:44:18 +02:00 by Jakub Uhlik · 9 comments
Mac OS X
Broken: 2.77a
Worked: 2.76b
different order of face vertices causing problems exporting meshes
list face vertices in both blender versions, lists won't be the same, eg:
l = [p.vertices[:] for p in me.polygons]
hello, i am writing exporter for Maxwell Render (https://github.com/uhlik/blendmaxwell). maxwell has feature of rendertime subdivision modifier. exactly same scene and same exporter revision creates same mesh visually, but because of different order of face vertices indexes, mesh from 2.77a with subdivision modifier refuses to render with error: "An edge connecting two vertices was specified more than once. It's likely that an incident face was flipped". the only difference is order of triangle vertices indexes returned from simple loop like the one above. was the behavior of polygon.vertices changed? haven't seen anything in release notes. or it is a bug? might cause problems for other exporters as well..
**System Information** Mac OS X **Blender Version** Broken: 2.77a Worked: 2.76b **Short description of error** different order of face vertices causing problems exporting meshes **Exact steps for others to reproduce the error** list face vertices in both blender versions, lists won't be the same, eg: ``` l = [p.vertices[:] for p in me.polygons] ``` hello, i am writing exporter for Maxwell Render (https://github.com/uhlik/blendmaxwell). maxwell has feature of rendertime subdivision modifier. exactly same scene and same exporter revision creates same mesh visually, but because of different order of face vertices indexes, mesh from 2.77a with subdivision modifier refuses to render with error: "An edge connecting two vertices was specified more than once. It's likely that an incident face was flipped". the only difference is order of triangle vertices indexes returned from simple loop like the one above. was the behavior of polygon.vertices changed? haven't seen anything in release notes. or it is a bug? might cause problems for other exporters as well..
Author
Author
Added subscriber: @JakubUhlik
Added subscriber: @mont29
Cannot reproduce that here, tested same file in 2.76b, 2.77a and current master and get exact same result. Please attach a .blend showing the issue.
Author
here is a blend. run script.a.blend
here is a blend. run script.[a.blend](https://archive.blender.org/developer/F312368/a.blend)
Added subscriber: @ideasman42
Ok, so this has nothing to do with py API, it’s just the triangulate BMesh operator that changed somehow… @ideasman42 may know better here, but I cannot see anything wrong in results of 2.76 or 2.77, order may change, but triangles and their winding remains the same.
Campbell Barton self-assigned this 2016-05-16 11:47:59 +02:00
Triangulation has had some tweaks since 2.76, unless the geometry is invalid. This isn't considered a bug.
Adding the following lines to the Text in a.blend shows there are no duplicate edges.
edges = [tuple(sorted(e.vertices)) for e in me.edges]
print(edges)
print(len(edges), len(set(edges)))
closing.
Triangulation has had some tweaks since 2.76, unless the geometry is invalid. This isn't considered a bug. Adding the following lines to the `Text` in `a.blend` shows there are no duplicate edges. ``` edges = [tuple(sorted(e.vertices)) for e in me.edges] print(edges) print(len(edges), len(set(edges))) ``` closing.
Reference: blender/blender#48444
