Cycles Spatial Splits BHV fails to complete build in scenes containing lots of hair along with SSS materials
Win10 64 bit; Third Gen i7 CPU; ATI HD7xxx GPU; 24 gigs RAM
Broken: Hash 89df672
Worked: Hash f70b548 (May16)
When the scene contains enough hair and the object it attaches to contains an SSS material, the Spatial Splits BVH build phase will suddenly stop and stay that way until Esc is pressed. This is only a Spatial Splits problem as turning off that checkbox allows the render to go like it should (it looks like a recent commit may be causing the build to lock up at a certain point).
Open the .blend file and try to render the scene
.blend
Adam Friesen (ace_dragon) set Type to Bug.
Adam Friesen (ace_dragon) updated the task description. (Show Details)
Adam Friesen (ace_dragon) created this task.
Adam Friesen (ace_dragon) renamed this task from Cycles Spatial Splits BHV build fails to complete build in scenes containing lots of hair along with SSS materials to Cycles Spatial Splits BHV fails to complete build in scenes containing lots of hair along with SSS materials.
Adam Friesen (ace_dragon) raised the priority of this task from to Needs Triage by Developer.
Sergey Sharybin (sergey) triaged this task as Confirmed, Medium priority.May 20 2016, 10:22 AM
