Viewer function in NodeWrangler addon don't work in Material Shading mode.
Win7 64Bit
GTX 460
Broken: git 2203444
Worked: 2.77
Viewer function of NodeWrangler addon (SHIFT+CTRL+CLICK on node) changes node linking but results are not updated in Material Shading mode. It shows results made by last manual linking of nodes OR work if Undo operation is invoked. In Rendered mode everything works fine.
  1. Enable NodeWrangler Addon.
  2. Load node_update_bug.blend.
  3. Click with SHIFT+CTRL on GradientTexture group node few times. This should update results in viewport but it don't.
  4. Use Undo couple of times and results are updated correctly.
Bartosz Moniewski (monio) set Type to Bug.
Bartosz Moniewski (monio) created this task.
Bartosz Moniewski (monio) raised the priority of this task from to Needs Triage by Developer.
@Aaron Carlisle (Blendify) - Today on IRC Sergey pointed me to assign this task to him. This issue is not necessarily related to addon itself. Will add Greg and Bartek as subscribers but reassigning this back to @Sergey Sharybin (sergey).
Sergey Sharybin (sergey) triaged this task as Confirmed, Medium priority.May 24 2016, 1:01 PM
