Black holes in Glossy Reflections
Debian 8 64bit, GTX 780
Broken: (example: 2.77a abf6f08, see splash screen)
There are black holes in reflections on the objects on some angles.
Take a look some screenshots.
Create simple scene with a cube, set smooth shading (IMPORTANT, this bug won't work on flat shading), add simple glossy material with roughness 0 (it will be easier to see these holes with low roughness), add HDR to environment. Go to render mode and watch at the surface. You will see black holes on surface. I think that it is the issue of normals interpolation, because you can add few levels of edge bevel.
But what if I don't want to add additional polygons with subdivide or bevel? Bug!
Ivan Lebedev (ITdreamer) updated the task description. (Show Details)
Ivan Lebedev (ITdreamer) raised the priority of this task from to Needs Triage by Developer.
Ivan Lebedev (ITdreamer) set Type to Bug.
Here is simple SCENE
This is not considered a bug, if the smooth normals of the mesh are very different than the actual mesh geometry we can't compute a correct reflection. Most renderers suffer from this issue in one way or another. We might find ways to improve this in the future, but for now it's a known limitation.
