bpy.ops.object.bake() #48693
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#48693
Ok writing it down for you :)
I wrote this:
https://github.com/florianfelix/render_bbake
I am calling object.bake in
https://github.com/florianfelix/render_bbake/blob/master/batch_bake_operators.py
on line 77.
I tried using save mode with 'EXTERNAL' and provided a filepath to filepath.
That doesn't seem to work?
Also when passing the name of a UVLayer to uv_layer it still renders on the active layer.
Third thing is more of a question:
What does pass_filter do? (There is no similar option exposed in regular vanilla baking?)
Thanks for looking and hoping not to have abused the bug reporting thing for this.
felix
Added subscriber: @florianfelix
blender/blender#74245 was marked as duplicate of this issue
Added subscribers: @vitorbalbio-3, @VilemDuha
@florianfelix pass_filter is explained here: https:*wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.77/Cycles#Baking or in the Cycles manual: https:*www.blender.org/manual/render/cycles/baking.html#options
As for the bug, can you reproduce this in a simpler script? Those options are supposed to be working.
@vitorbalbio-3 is the API still working for your Addon?
@VilemDuha how about you?
Added subscriber: @JasonG
I've just noticed this as well. I was writing some support scripts for a project and need to do some scripted baking.
From the default scene, unwrap the cube and run this with it selected:
I get the following error:
I'm currently using the latest public build, nothing special.
Since day 1 (blender/blender@97641a0e) you can see that external saving was not really supported. The code explicitly forces the mode to be internal. I will mark it as a TODO and close the report for now.
Added subscribers: @KenzieMac130, @iss
