New GGX breaks OpenCL kernel #48732
Closed
opened 2016-06-25 00:22:01 +02:00 by mathieu menuet · 22 comments
R9 280X, Catalyst 16.3 on win 7 x64
Broken: 823ab66
broken kernel
Hit F12 on default scene with cycles and GPU/OpenCL enabled:
Device init success
Compiling OpenCL kernel ...
Build flags: -D__NODES_MAX_GROUP__=3 -D__NODES_FEATURES__=4 -D__MAX_CLOSURE__=5
-D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D__NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__
NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__
OpenCL kernel build output:
"C:\Users\test\AppData\Local\Temp\OCL2992T1.cl", line 81696: error: expression must have arithmetic, enum, or pointer type
        if(sc->T == make_float3(0.0f, 0.0f, 0.0f))
1 error detected in the compilation of "C:\Users\test\AppData\Local\Temp\OCL2992T1.cl".
Frontend phase failed compilation.
OpenCL build failed: errors in console
Error: OpenCL build failed: errors in console
**System Information** R9 280X, Catalyst 16.3 on win 7 x64 **Blender Version** Broken: 823ab66 **Short description of error** broken kernel **Exact steps for others to reproduce the error** Hit F12 on default scene with cycles and GPU/OpenCL enabled: ``` Device init success Compiling OpenCL kernel ... Build flags: -D__NODES_MAX_GROUP__=3 -D__NODES_FEATURES__=4 -D__MAX_CLOSURE__=5 -D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D__NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__ NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__ OpenCL kernel build output: "C:\Users\test\AppData\Local\Temp\OCL2992T1.cl", line 81696: error: expression must have arithmetic, enum, or pointer type if(sc->T == make_float3(0.0f, 0.0f, 0.0f)) ^ 1 error detected in the compilation of "C:\Users\test\AppData\Local\Temp\OCL2992T1.cl". Frontend phase failed compilation. OpenCL build failed: errors in console Error: OpenCL build failed: errors in console ```
Author
Author
Added subscriber: @bliblubli
This issue was referenced by blender/cycles@fb9833c20f
This issue was referenced by blender/cycles@fb9833c20f94febd9bcd7e8ea2d11a73f7b48ab7
This issue was referenced by 99088f8b55
This issue was referenced by 99088f8b552ccbdff5834a060a2a2e032e25f0b5
Author
Hi,
it still broken:
Build flags: -D__NODES_MAX_GROUP__=3 -D__NODES_FEATURES__=7 -D__MAX_CLOSURE__=64
_NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__
Kernel compilation finished in 3.45s.
Build flags: -D__SPLIT_KERNEL__ -D__WORK_STEALING__ -D__NODES_MAX_GROUP__=3 -D__
NODES_FEATURES__=7 -D__MAX_CLOSURE__=64 -D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D_
_NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_B
RANCHED_PATH__ -D__COMPUTE_DEVICE_GPU__
"C:\Users\test\AppData\Local\Temp\OCL2396T2.cl", line 45818: error: argument of type "__global uint *" is incompatible with parameter of type
          "uint *"
                                eval, omega_in,  &domega_in->dx, &domega_in->dy, pdf, &ccl_fetch(sd, lcg_state));
"C:\Users\test\AppData\Local\Temp\OCL2396T2.cl", line 45822: error: argument of type "__global uint *" is incompatible with parameter of type "uint *"
                                eval, omega_in,  &domega_in->dx, &domega_in->dy, pdf, &ccl_fetch(sd,lcg_state));
"C:\Users\test\AppData\Local\Temp\OCL2396T2.cl", line 45912: error: argument of type "__global uint *" is incompatible with parameter of type "uint *"
                                eval = bsdf_microfacet_multi_ggx_eval_reflect(sc, ccl_fetch(sd, I), omega_in, pdf, &ccl_fetch(sd, lcg_state));
"C:\Users\test\AppData\Local\Temp\OCL2396T2.cl", line 45915: error: argument of type "__global uint *" is incompatible with parameter of type "uint *"
                                eval = bsdf_microfacet_multi_ggx_glass_eval_refl
"C:\Users\test\AppData\Local\Temp\OCL2396T2.cl", line 45980: error: argument of type "__global uint *" is incompatible with parameter of type "uint *"
                                eval = bsdf_microfacet_multi_ggx_eval_transmit(sc, ccl_fetch(sd, I), omega_in, pdf, &ccl_fetch(sd, lcg_state));
"C:\Users\test\AppData\Local\Temp\OCL2396T2.cl", line 45983: error: argument of type "__global uint *" is incompatible with parameter of type "uint *"
                                eval = bsdf_microfacet_multi_ggx_glass_eval_transmit(sc, ccl_fetch(sd, I), omega_in, pdf, &ccl_fetch(sd, lcg_state));
"C:\Users\test\AppData\Local\Temp\OCL2396T2.cl", line 53187: error: argument of type "__global PathState *" is incompatible with parameter of type "const PathState *"
                ccl_fetch(sd, lcg_state) = lcg_state_init(rng, state, 0xb4bc3953
7 errors detected in the compilation of "C:\Users\test\AppData\Local\Temp\OCL2396T2.cl".
Faled to compile data_init
Hi, it still broken: ``` Compiling OpenCL kernel ... Build flags: -D__NODES_MAX_GROUP__=3 -D__NODES_FEATURES__=7 -D__MAX_CLOSURE__=64 -D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D__NO_CAMERA_MOTION__ -D__NO_BAKING__ -D_ _NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__ Kernel compilation finished in 3.45s. Compiling OpenCL kernel ... Build flags: -D__SPLIT_KERNEL__ -D__WORK_STEALING__ -D__NODES_MAX_GROUP__=3 -D__ NODES_FEATURES__=7 -D__MAX_CLOSURE__=64 -D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D_ _NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_B RANCHED_PATH__ -D__COMPUTE_DEVICE_GPU__ OpenCL kernel build output: "C:\Users\test\AppData\Local\Temp\OCL2396T2.cl", line 45818: error: argument of type "__global uint *" is incompatible with parameter of type "uint *" eval, omega_in, &domega_in->dx, &domega_in->dy, pdf, &ccl_fetch(sd, lcg_state)); ^ "C:\Users\test\AppData\Local\Temp\OCL2396T2.cl", line 45822: error: argument of type "__global uint *" is incompatible with parameter of type "uint *" eval, omega_in, &domega_in->dx, &domega_in->dy, pdf, &ccl_fetch(sd,lcg_state)); ^ "C:\Users\test\AppData\Local\Temp\OCL2396T2.cl", line 45912: error: argument of type "__global uint *" is incompatible with parameter of type "uint *" eval = bsdf_microfacet_multi_ggx_eval_reflect(sc, ccl_fetch(sd, I), omega_in, pdf, &ccl_fetch(sd, lcg_state)); ^ "C:\Users\test\AppData\Local\Temp\OCL2396T2.cl", line 45915: error: argument of type "__global uint *" is incompatible with parameter of type "uint *" eval = bsdf_microfacet_multi_ggx_glass_eval_refl ect(sc, ccl_fetch(sd, I), omega_in, pdf, &ccl_fetch(sd, lcg_state)); ^ "C:\Users\test\AppData\Local\Temp\OCL2396T2.cl", line 45980: error: argument of type "__global uint *" is incompatible with parameter of type "uint *" eval = bsdf_microfacet_multi_ggx_eval_transmit(sc, ccl_fetch(sd, I), omega_in, pdf, &ccl_fetch(sd, lcg_state)); ^ "C:\Users\test\AppData\Local\Temp\OCL2396T2.cl", line 45983: error: argument of type "__global uint *" is incompatible with parameter of type "uint *" eval = bsdf_microfacet_multi_ggx_glass_eval_transmit(sc, ccl_fetch(sd, I), omega_in, pdf, &ccl_fetch(sd, lcg_state)); ^ "C:\Users\test\AppData\Local\Temp\OCL2396T2.cl", line 53187: error: argument of type "__global PathState *" is incompatible with parameter of type "const PathState *" ccl_fetch(sd, lcg_state) = lcg_state_init(rng, state, 0xb4bc3953 ); ^ 7 errors detected in the compilation of "C:\Users\test\AppData\Local\Temp\OCL2396T2.cl". Frontend phase failed compilation. OpenCL build failed: errors in console Faled to compile data_init ```
Author
Changed status from 'Resolved' to: 'Open'
Added subscribers: @LukasStockner, @ThomasDinges
Tested on nvidia opencl, don't have a AMD card to test here. @LukasStockner any idea?
Member
@ThomasDinges, apparently I forgot the OpenCL-compliant syntax (ccl_fetch(), the addr_space keywords etc.) - I'll fix it as soon as possible.
Lukas Stockner self-assigned this 2016-06-25 22:19:07 +02:00
This issue was referenced by blender/cycles@ace4aab253
This issue was referenced by blender/cycles@ace4aab2538470f3514bd340ca38d7f31993361d
This issue was referenced by 2a69b09b62
This issue was referenced by 2a69b09b62c2f339f68883c9c7edfc4a6dd1ef8d
Member
Author
Author
Maybe the foundation could invest 90€ in an AMD GPU for you Lukas ? With all what you do for cycles, it would help you a lot to test. In the meantime, I can report each step:
Build flags: -D__NODES_MAX_GROUP__=2 -D__NODES_FEATURES__=0 -D__MAX_CLOSURE__=1
Kernel compilation finished in 2.36s.
Build flags: -D__SPLIT_KERNEL__ -D__WORK_STEALING__ -D__NODES_MAX_GROUP__=2 -D__
NODES_FEATURES__=0 -D__MAX_CLOSURE__=1 -D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D__
NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BR
"C:\Users\test\AppData\Local\Temp\OCL2104T2.cl", line 22176: error: argument of type "uint *" is incompatible with parameter of type "__global uint *"
        lcg_step_uint(&rng);
1 error detected in the compilation of "C:\Users\test\AppData\Local\Temp\OCL2104T2.cl".
Maybe the foundation could invest 90€ in an AMD GPU for you Lukas ? With all what you do for cycles, it would help you a lot to test. In the meantime, I can report each step: ``` Compiling OpenCL kernel ... Build flags: -D__NODES_MAX_GROUP__=2 -D__NODES_FEATURES__=0 -D__MAX_CLOSURE__=1 -D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D__NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__ NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__ Kernel compilation finished in 2.36s. Compiling OpenCL kernel ... Build flags: -D__SPLIT_KERNEL__ -D__WORK_STEALING__ -D__NODES_MAX_GROUP__=2 -D__ NODES_FEATURES__=0 -D__MAX_CLOSURE__=1 -D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D__ NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BR ANCHED_PATH__ -D__COMPUTE_DEVICE_GPU__ OpenCL kernel build output: "C:\Users\test\AppData\Local\Temp\OCL2104T2.cl", line 22176: error: argument of type "uint *" is incompatible with parameter of type "__global uint *" lcg_step_uint(&rng); ^ 1 error detected in the compilation of "C:\Users\test\AppData\Local\Temp\OCL2104T2.cl". Frontend phase failed compilation. OpenCL build failed: errors in console Faled to compile data_init Error: OpenCL build failed: errors in console ```
Member
Well, I suppose I could try to install the AMD CPU runtime as well...
Anyways, instead of committing tons of additional "fixes", I think it would be best if you tried them out first :)
Could you remove the "ccl_addr_space" in kernel_random.h, line 235 (ccl_device uint lcg_step_uint(ccl_addr_space uint *rng) to ccl_device uint lcg_step_uint(uint *rng)) and see if it works that way?
The file is in intern/cycles/kernel/ if you build from the source yourself, and in 2.77/scripts/addons/cycles/kernel/ if you use the buildbot builds.
Well, I suppose I could try to install the AMD CPU runtime as well... Anyways, instead of committing tons of additional "fixes", I think it would be best if you tried them out first :) Could you remove the "ccl_addr_space" in kernel_random.h, line 235 (`ccl_device uint lcg_step_uint(ccl_addr_space uint *rng)` to `ccl_device uint lcg_step_uint(uint *rng)`) and see if it works that way? The file is in intern/cycles/kernel/ if you build from the source yourself, and in 2.77/scripts/addons/cycles/kernel/ if you use the buildbot builds.
Author
As you wish, I can report back errors on every step or you can install the compiler. Latest proposed change done, new error is:
Device init success
Kernel compilation finished in 2.26s.
Kernel compilation finished in 1.13s.
Kernel compilation finished in 0.67s.
Kernel compilation finished in 2.03s.
Kernel compilation finished in 0.12s.
Kernel compilation finished in 3.12s.
"C:\Users\test\AppData\Local\Temp\OCL2848T7.cl", line 58112: error: argument
          of type "__global uint *" is incompatible with parameter of type "RNG *"
                shader_eval_surface(kg, sd, rng, state, rbsdf, state->flag, SHADER_CONTEXT_MAIN);
1 error detected in the compilation of "C:\Users\test\AppData\Local\Temp\OCL2848T7.cl".
Faled to compile shader_eval
As you wish, I can report back errors on every step or you can install the compiler. Latest proposed change done, new error is: ``` Device init success Compiling OpenCL kernel ... Build flags: -D__NODES_MAX_GROUP__=2 -D__NODES_FEATURES__=0 -D__MAX_CLOSURE__=1 -D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D__NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__ NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__ Kernel compilation finished in 2.26s. Compiling OpenCL kernel ... Build flags: -D__SPLIT_KERNEL__ -D__WORK_STEALING__ -D__NODES_MAX_GROUP__=2 -D__ NODES_FEATURES__=0 -D__MAX_CLOSURE__=1 -D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D__ NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BR ANCHED_PATH__ -D__COMPUTE_DEVICE_GPU__ Kernel compilation finished in 1.13s. Compiling OpenCL kernel ... Build flags: -D__SPLIT_KERNEL__ -D__WORK_STEALING__ -D__NODES_MAX_GROUP__=2 -D__ NODES_FEATURES__=0 -D__MAX_CLOSURE__=1 -D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D__ NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BR ANCHED_PATH__ -D__COMPUTE_DEVICE_GPU__ Kernel compilation finished in 0.67s. Compiling OpenCL kernel ... Build flags: -D__SPLIT_KERNEL__ -D__WORK_STEALING__ -D__NODES_MAX_GROUP__=2 -D__ NODES_FEATURES__=0 -D__MAX_CLOSURE__=1 -D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D__ NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BR ANCHED_PATH__ -D__COMPUTE_DEVICE_GPU__ Kernel compilation finished in 2.03s. Compiling OpenCL kernel ... Build flags: -D__SPLIT_KERNEL__ -D__WORK_STEALING__ -D__NODES_MAX_GROUP__=2 -D__ NODES_FEATURES__=0 -D__MAX_CLOSURE__=1 -D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D__ NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BR ANCHED_PATH__ -D__COMPUTE_DEVICE_GPU__ Kernel compilation finished in 0.12s. Compiling OpenCL kernel ... Build flags: -D__SPLIT_KERNEL__ -D__WORK_STEALING__ -D__NODES_MAX_GROUP__=2 -D__ NODES_FEATURES__=0 -D__MAX_CLOSURE__=1 -D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D__ NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BR ANCHED_PATH__ -D__COMPUTE_DEVICE_GPU__ Kernel compilation finished in 3.12s. Compiling OpenCL kernel ... Build flags: -D__SPLIT_KERNEL__ -D__WORK_STEALING__ -D__NODES_MAX_GROUP__=2 -D__ NODES_FEATURES__=0 -D__MAX_CLOSURE__=1 -D__NO_HAIR__ -D__NO_OBJECT_MOTION__ -D__ NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BR ANCHED_PATH__ -D__COMPUTE_DEVICE_GPU__ OpenCL kernel build output: "C:\Users\test\AppData\Local\Temp\OCL2848T7.cl", line 58112: error: argument of type "__global uint *" is incompatible with parameter of type "RNG *" shader_eval_surface(kg, sd, rng, state, rbsdf, state->flag, SHADER_CONTEXT_MAIN); ^ 1 error detected in the compilation of "C:\Users\test\AppData\Local\Temp\OCL2848T7.cl". Frontend phase failed compilation. OpenCL build failed: errors in console Faled to compile shader_eval ```
Member
Okay, next step: In kernel_shader.h, line 830 (same folder as before), add ccl_addr_space in front of RNG (ccl_device void shader_eval_surface(KernelGlobals *kg, ShaderData *sd, RNG *rng, to ccl_device void shader_eval_surface(KernelGlobals *kg, ShaderData *sd, ccl_addr_space RNG *rng,).
Okay, next step: In kernel_shader.h, line 830 (same folder as before), add ccl_addr_space in front of RNG (`ccl_device void shader_eval_surface(KernelGlobals *kg, ShaderData *sd, RNG *rng,` to `ccl_device void shader_eval_surface(KernelGlobals *kg, ShaderData *sd, ccl_addr_space RNG *rng,`).
Author
"C:\Users\test\AppData\Local\Temp\OCL2484T2.cl", line 53187: error: argument
          of type "__global RNG *" is incompatible with parameter of type "RNG *"
                ccl_fetch(sd, lcg_state) = lcg_state_init(rng, state, 0xb4bc3953);
1 error detected in the compilation of "C:\Users\test\AppData\Local\Temp\OCL2484T2.cl".
``` "C:\Users\test\AppData\Local\Temp\OCL2484T2.cl", line 53187: error: argument of type "__global RNG *" is incompatible with parameter of type "RNG *" ccl_fetch(sd, lcg_state) = lcg_state_init(rng, state, 0xb4bc3953); ^ 1 error detected in the compilation of "C:\Users\test\AppData\Local\Temp\OCL2484T2.cl". Frontend phase failed compilation. OpenCL build failed: errors in console Faled to compile data_init ```
This issue was referenced by blender/cycles@6e89e10d7a
This issue was referenced by blender/cycles@6e89e10d7a8431b7f58c71e48dd16b5747daa985
This issue was referenced by 23cc453975
This issue was referenced by 23cc453975c42069bac21e849b1bf7e3e60cd8e7
5 Participants
Reference: blender/blender#48732
