UI Naming Convention #48742
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#48742
window, screen, area, [space] editor, region (header, Tool Shelf, Prop. Region, Operator panel), tab, panel
footer (statusbar i.e. on tranformation)
Operator:
button: operator, menuItem
menu: menubutton
menu enum: drop-down
Inputs:
pop-up(menu enum/ select): selector, flyout, dialog
select: selector, droplist,
combobox: data-block menu
combobox: (text + list; select + text)
color button: swatch, field, selector
checkbox, toggle
radiobutton
textbox, searchbox
number up down: number button
range: slider
Widgets:
Add-on:
Output:
fully: context > properties editor tab, toolbar > header, window > editor, sidebar > properties region
properties panel (N) to properties region
partially: viewport > 3D View
Added subscriber: @Tobias
You should avoid calling the region that appears on the right by hitting N a 'panel' since 'panels' are the drag-able and collapsible button containers. I usually refer to it as the properties region since it's technically correct. We also discussed this in blender/blender#43623 but without much success.
Added subscriber: @BrendonMurphy
hi,
The Tool Shelf includes Tabs & Tool Shelf Panels.
The Properties Shelf includes the Properties Shelf Panels.
This is consistent.
The word Shelf, correctly describes the menu style for these areas. Where confusion comes in is the wrong naming of the Properties Shelf such as Properties Region, Properties Area or any other wrong description. These become more confusing in context when describing the Properties Editor.
When & decision is made here I'll update all addons to make sure they follow convention.
How to call the "Operator panel" Blender at the bottom of the tool shelf
in the manual it is named "context-sensitive panel"
tool + operator panel?
Now that bigger ui elements are >< sort out to the small buttons:
my idea: everything that overlaps is a pop-up (transp. black box)
but how to call the : classical menubar menu button, menu-enum button and color button
menu-enum: dropdown, droplist
color: swatch, field, selector
combobox (text input + list): Selector
Added subscriber: @Blendify
@JulianEisel I will be closing this soon. Do you think this should go on the wiki somewhere? Is so then where?
