Stuck in edit mode after object change via animation window object lists. #48747
Closed
opened 2016-06-27 12:36:58 +02:00 by Mort · 6 comments
Windows build (likely all)
BF 277a
By switching selected object via the dope sheet, graph editor or NLA window (possibly others?) it is possible to lock the system into edit mode of a non-selected object (i.e. tab will not exit edit mode as a different object is active) with no obvious method to make the first active again (and thus allow exiting edit mode)
In a scene with at least two objects:
Enter edit mode on the first, then LMB on the name of the second in a dope sheet window, you can now no longer tab out of edit mode and are somewhat stuck.
Note:
  • The outliner does not show this behavior.
  • By using the dopesheet/outliner etc it is possible to set the first object back to active and exit edit mode.
Apologies if this has already been reported, I did a quick search but am far too busy to dig deep.
Windows build (likely all) BF 277a By switching selected object via the dope sheet, graph editor or NLA window (possibly others?) it is possible to lock the system into edit mode of a non-selected object (i.e. tab will not exit edit mode as a different object is active) with no obvious method to make the first active again (and thus allow exiting edit mode) In a scene with at least two objects: Enter edit mode on the first, then LMB on the name of the second in a dope sheet window, you can now no longer tab out of edit mode and are somewhat stuck. Note: - The outliner does not show this behavior. - By using the dopesheet/outliner etc it is possible to set the first object back to active and exit edit mode. Apologies if this has already been reported, I did a quick search but am far too busy to dig deep.
Author
Author
Added subscriber: @MortOOPz
Author
Oh, it only locks if the second object doesn't have an edit mode (e.g. an empty).
Member
Added subscriber: @JoshuaLeung
Joshua Leung self-assigned this 2016-06-27 15:49:10 +02:00
This issue was referenced by 7793d1d26f
This issue was referenced by 7793d1d26f28459c477f71fcd2ee662a7e14dd04
Member
Reference: blender/blender#48747
