Displace modifier ignores 'Simple' subdivision if scale is unapplied
Closed, InvalidPublic
Windows 10 64-bit, Nvidia gtx 570 (render), Nvidia gt 610 (display)
Broken: 2.77a, a92fc34
Worked: -
The displace modifier ignores the Subsurf modifier if the Subsurf's subdivision type is set to 'Simple' and the scale on the object is unapplied. I understand applying scale is often important for modifiers to work correctly, but what threw me off was the fact that normal 'Catmull-Clark' subdivision works fine but 'Simple' shows no effect at all.
  1. Open
  2. Switch the 'Subsurf' modifier's subdivision type from 'Simple' (no effect) to 'Catmull-Clark' to see the effects of the Displace modifier.
I think this is not a bug, just the cloud procedural giving those zero values at those local coords...
Will double check in a bit...
Yep, looks like clouds procderural at scale 1 will give output values of .5 at corners [0,0], [0,1], [1,1], [1,0]
--> So no displacement there
file from report uses clouds at scale .25 which will give no displacement at all vertices even at subd level 2 or 3.
havent looked at the actual code but some other things to try:
  • try subdividing further and displacement will show up
  • try translating vertices in editmode and displacement will show up
  • try using global coords in displace modifier and displacement will show up
  • try any other procedural [voronoi or something] and displacement will show up
  • try altering the colors of the cloud procedural with a ramp and displacement will show up
Can totally confirm @Philipp Oeser (lichtwerk) diagnostic here… No bug at all, just odd effect of procedural textures!
