Bone custom shaping allows for semi-orphaning #48865
2 Participants
Reference: blender/blender#48865
Win7 Prof x64, 32gb, i5 6600, 2x GTX 970
Broken: 2.77a
abf6f08
Using an object as custom shape for a bone allows the deletion of the object without actually removing it from the file because the bone is still using it.
This will lead to the situation where the object is non-existant in the scene but still referenced and kept around.
Create an object (I used an UV sphere)
Create an armature (I used a simple single bone one)
Assign the object to the bone as shape
Delete the object
Save the file and reopen it (I did via recent files)
Check the Outliner for the sphere, it still exists under Blendfile and Data Blocks but will be non-existant in the scene itself and is out of reach now.
So far I am not aware of any way to get the object back into the scene and the only way I found to clean such a mess up is recreating the objects, reassigning the bones and then clean up the file to get rid of the semi-orphans which turned luckily into true orphans after they weren't used anymore.
I'd propose that bones get changed to use meshes instead of objects because in that case you could just create a plane and change it's mesh to get the access back, but I'm pretty sure that's no simple change.
Maybe the simplest approach would be to offer a way to recover referenced objects that are not present in any scene?
Added subscriber: @BloodyRain
Added subscriber: @mont29
Thanks for the report, but there’s not really any bug here, the object can simply be 'cleaned out' by removing its usage from bone shape (and then save/reload).
Beyond that, it's known limitation of current system, having a way to re-instantiate an object from user UI is a nice TODO.
