EnumProperty using update function and expand option is not correctly drawing
Blender 2.77 linux 64
This code give very strange and unpredictable results (see attached screeshoots). But work correctly if the property is displayed without expand option.
import bpy
def getValues(self, context):
    items = []
    values = ['value' + str(i+1) for i in range(10)]
    for i, v in enumerate(values):
        #put each item in a tuple (key, label, tooltip)
        items.append( (str(i), str(i+1)+' '+v, v) )
    return items
bpy.types.Scene.values = bpy.props.EnumProperty(
        name = "Values",
        items = getValues)
class PANEL(bpy.types.Panel):
    bl_category = "TEST"
    bl_label = "Show bug"
    bl_space_type = "VIEW_3D"
    bl_context = "objectmode"
    bl_region_type = "TOOLS"
    def draw(self, context):
        scn = context.scene
        layout = self.layout
        row = layout.row()
        col = row.column()
        col.prop(scn, "values", expand=True) #messup
        layout.prop(scn, "values") #always correct
bpy.utils.register_module(__name__)
