Blender Cloud integration in Blender #48905
legacy module
legacy project
Blender Cloud
legacy project
Documentation
legacy project
Infrastructure: blender.org
legacy project
Infrastructure: Websites
legacy project
legacy project
Pillar
legacy project
Pillar Framework
Priority::High
Priority::Low
Priority::Normal
Status::Archived
Status::Confirmed
Status::Duplicate
Status::Needs Triage
Status::Resolved
Type::Bug
Type::Design
Type::Report
Type::To Do
2 Participants
Reference: archive/blender-cloud#48905
We are planning some steps to improve the integration of Blender with the Blender Cloud. The goals are:
Our main motivation is to get some quick tools to allow for such easier interaction, before the asset engine project is completed.
Use case: image variant selection
The first planned use case is to allow the selection of variants of an image (in terms of resolution), within an image datablock.
The expected workflow is:
Image data structure on Blender Cloud
Blender Cloud runs on the Pillar Framework and it uses flat-node-based data structures. In the case of an image we have the following (simplified) data:
We plan to generate a enum-based interface that easily allows the selection of a
file
, using theresolution
attribute as a label. This will then trigger a callback which will download or fetch from a cache the selected file.Visualizing datablocks connected with the Cloud
We want to be aware about which content has been assigned attributes that can be used by the Blender Cloud Add-on.
Our planned solution is to display additional text, or a standard label, on all such content. For example: in the Image Editor, we could display the Cloud icon in the header. The goal is to be informative, but not intrusive.
Added subscriber: @fsiddi
Added subscriber: @dr.sybren
