different Skin Modifier outputs for same mesh
Open, Confirmed, MediumPublic
Windows 10
Nvidia Quadro 600
Broken: 1422f0d
The skin modifier produces different meshes on the default cube.
Trigger the skin modifier to update by doing the same thing I do in the .gif
Note: this only seems to happen when the edges are orthogonal. When I move one point, the problem doesn't appear on this and connected points.
(Originially reported here: https://github.com/JacquesLucke/animation_nodes/issues/576)
Bastien Montagne (mont29) triaged this task as Confirmed, Medium priority.Jul 23 2016, 11:03 PM
Can confirm the issue (note that you do not need the subsurf modifier at all, default cube with default skin modifier exhibits the same behavior).
Not sure whether this is bug or known behavior - skin code so not so easy to follow, yet on a very quick glance I do not see anything that could explain that erratic behavior (no threaded parts e.g.)…
What's even stranger adding a new object, for instance a cylinder and changing the number of vertices in the operator panel will trigger the update on the skin modifier.
